Few more questions
johninspain
Few more questions
Post by johninspain » Thu Jan 14, 2010 5:23 pm
Firstly can you tell im bord ? Secondly sorry for all the different posts, i just like to know what im dealing with !
what oil are you all on ?
can it run on 95 fule ?
Has anyone used an additive, for boostingthe octain or for cleaning the motor ?
RE: Few more questions
Post by HYFR » Thu Jan 14, 2010 5:27 pm
dont run it on 95 fuel, i run on 99 only
gmk666
Post by gmk666 » Thu Jan 14, 2010 5:30 pm
I'm using Castrol Edge, 5w30. It's VW 504 507 rated and I'm told is what the car came with from the factory.
I've only ever used 95RON fuel in an emergency - not all small garages in the UK have the much more preferred 98RON.
johninspain
Post by johninspain » Thu Jan 14, 2010 5:30 pm
98 is the best out here,,,,,, if your lucky.....
997 turbo (uk)
Khan Range Rover TD V8 (UK)
RS4 (Spain)
CLK Convertable (Spain)
Ferrari 458 on order (now sold my order) !
Outtlaw
Post by Outtlaw » Thu Jan 14, 2010 5:33 pm
Only run it on 99 but if stuck put a little of 95 till you see the next petrol station, as for oil i use castrol but you have to check the dipstick constantly.
Outtlaw
Post by Outtlaw » Thu Jan 14, 2010 5:34 pm
urrrrr i type to slow.
sonny
Post by sonny » Thu Jan 14, 2010 5:49 pm
Castrol Edge 5w30
97/98 and 99 RON fuel.
Does Spain have the same RON rating as the UK, I know in the states its different, 93 RON is 98 RON UK. (Arthur correct me). what does it say on the inside of your filler cap, should have it in a Spanish RON.
johninspain
Re: RE: Few more questions
Post by johninspain » Thu Jan 14, 2010 5:51 pm
sonny wrote:Castrol Edge 5w30
good idea !
PetrolDave
RE: Re: RE: Few more questions
Post by PetrolDave » Thu Jan 14, 2010 8:11 pm
AFAIK the EU all use RON octane ratings, where the US use the average of MON and RON ratings.
MB2
Post by MB2 » Thu Jan 14, 2010 9:17 pm
I haven't had mine too long & have run it mostly on Shell Super 99 or whatever it is called. If I know will be doing a long mway run I tend to top up with std UL as is a bit cheaper although many say the mpg is better with the higher octane stuff. I used to run my R32 (also meant to have super) on std & was fine but am more careful with the RS4 as engine is in a higher state of tune. Oil I use Castrol Edge (left over from the R32 but correct spec for both cars)
johninspain
Post by johninspain » Thu Jan 14, 2010 9:22 pm
so 95 for a m way run ?
997 turbo (uk)
RS4 (Spain)
sonny
Post by sonny » Thu Jan 14, 2010 9:28 pm
It will cost you more to use the cheaper fuel lol due to the burn rate of the fuel. so even if the fuel is more expensive you will get more MPG from it, there for it is actually cheaper.
P_G
Post by P_G » Thu Jan 14, 2010 10:23 pm
johninspain wrote:so 95 for a m way run ?
I wouldn't bother TBH. I used to do that but the mpg difference is about 10% worse with 95RON unleaded in the UK and costs 3-5% less so no gain at all. Better to economise your use of your lead foot.
Plus the RS feels dog rough and takes a couple of tanks of 98/99 to get its normal sharpness back.
There is also a theory posted on this forum that using 95 RON may contribute more to carbonisation of the valves. It say on the filler flap min 97 RON, it is usually for a reason.
johninspain
Post by johninspain » Thu Jan 14, 2010 10:38 pm
just looked at filler cap, says 98 or 95................
997 turbo (uk)
RS4 (Spain)
P_G
Post by P_G » Thu Jan 14, 2010 10:40 pm
Using 95 won't get all the ponies or torques working in your engine either.
Users browsing this forum: Google Adsense [Bot] and 85 guests
