Disks replaced
2.7 V6 30v biturbo - 380 bhp
Bushy
Re: Disks replaced
Post by Bushy » Fri Jan 10, 2003 12:06 pm
The struts are swopped across when MoVits are fitted, otherwise you have to pay £600 for new ones Image.
Only Problem is if you sell the car they must be sold on it.
jr
These are just the rear struts for the movit set up as they are machined slightly
However as Toasty has an S4 I thought he would have to change his front struts to accept the RS4 discs???
Although not totally sure
What discs and calipres have you got Steve?
I heard from AP Racing and was quoted around £1600 but on RS4.org a few comments were made that they did not wear as well as the Movits?
Can't beat a bit of boost!
Thorney
Location: Wherever the centre of the universe is, I'm about as far away from it as possible.
Re: Disks replaced
Post by Thorney » Fri Jan 10, 2003 1:10 pm
Well I'm getting a second hand set of Brembo's which as they make all the others anyway I'm pleased.
Will check on S4 compatiability first obviously.
rs4steve
Re: Disks replaced
Post by rs4steve » Fri Jan 10, 2003 9:07 pm
i bought the 6pots + discs(continuous groove type) separately then i used my local brake manufacturer to make the brackets and bells, bells made out of "hard alloy" allowing for different heat dissipation away from disc, on the ap kit the bell is made from same material so keeps the heat longer: as alloy cools quicker the disc temp is lower. clever stuff!
Bushy
Re: Disks replaced
Post by Bushy » Sat Jan 11, 2003 9:57 am
and how can we all benefit from your experiments?
is it something that you can get several sets made up?
if so
how much
rs4steve
Re: Disks replaced
Post by rs4steve » Sat Jan 11, 2003 5:39 pm
will make some enquires into prices, time of manufacturer. what material are your bells made of at the minute? not possible on standard disc as one piece, would be possible on after market setup: im also at minute having some rear ap discs made up to run with the standard calipers.
Bushy
Re: Disks replaced
Post by Bushy » Sun Jan 12, 2003 12:39 pm
be interestred in the rears
currently have movit fronts but not over happy
performance is fine
just the paint is coming off!!
johneroberts
Re: Disks replaced
Post by johneroberts » Sun Jan 12, 2003 4:13 pm
Im off to AmD on Wednesday for new rotors as the last ones onnly lasted 7 months Image
Also MoVit are going to at some point refurbish my front calipers as my paints peeling too.
Its not really good enough for thhat sort of money!!!
jr
Driving is believing
RS246 Founder
Andiroo
Re: Disks replaced
Post by Andiroo » Sun Jan 12, 2003 6:19 pm
Maybe I've been lucky with the Sportec 380mm (Brembo rear), no warped discs or problems of any kind after 22k miles and lots of trackdays, there again I do tend to maintain/service them regularly, even if its just a clean and prep of the pad/disc surface - maybe that's the key?
In any case they all should have a reasonable lifespan in terms of quality and finish, maybe we're asking too much?
Steve, looking forward to seeing your AP's up close, especially in terms of quality and performance compared to us Porsche/Brembo/Movit/Sportec clones Image
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Users browsing this forum: Yahoo [Bot] and 42 guests
