Has anyone cut away their large mid silencers and replaced instead with straight through pipes - i.e. leaving the rear silencer and cats untouched.
On having my car up on our ramps would look like a fairly easy job to do, a lot less expense than a catback, and might release some of the v8 glory
Anyone tried this and if so what were the results?
exhaust - cutting our mid silencer and replacing with pipes
Grazer_skredge
- 1st Gear
RE: exhaust - cutting our mid silencer and replacing with pi
i had this on my car for a little while http://www.ecstuning.com/Audi-B7_RS4--V ... S/ES11361/ it was great for what it was but its just not the same as a full exhaust setup
2007 rs4 mugello blue premium package, sirius, black optic grill, miltek non-res non-valved catback, milltek dp's, stasis/alcon clutch, bodymatched reflectors, tints, xenon interior bulbs, KW V3, 10mm h&r spacers, REVO flash, K&N drop in filter, euro steering wheel, jhm short throw,De-Flapped, ac glove mod, IMA multimedia adapter, h-sport sways, some alcantra on the way
Grazer, have a look at this;
http://www.rs246.com/index.php?name=PNp ... hlight=aas
AAS still have the design available should you want to contact them for them to fabricate one and send it to you unless you want to make a trip to Newcastle when they would do the job in a day.
The sound may not be the same as a full exhaust set up but not far off and this way you retain external OEM look plus use of the valves and it is only circa £300 as opposed to a £thousand plus for a full set up.
Sounded good but adding a BMC air filter has helped it sound even better.
P_G wrote:Grazer, have a look at this;
The sound may not be the same as a full exhaust set up but not far off and this way you retain external OEM look plus use of the valves and it is only circa £300 as opposed to a £thousand plus for a full set up. X-pipes also have slight performance and fuel economy gains.
Grazer_skredge
- 1st Gear
Grazer_skredge
- 1st Gear
Users browsing this forum: Bing [Bot] and 264 guests
