exhaust - cutting our mid silencer and replacing with pipes
Grazer_skredge
Post by Grazer_skredge » Mon Sep 21, 2009 4:19 pm
Has anyone cut away their large mid silencers and replaced instead with straight through pipes - i.e. leaving the rear silencer and cats untouched.
On having my car up on our ramps would look like a fairly easy job to do, a lot less expense than a catback, and might release some of the v8 glory
Anyone tried this and if so what were the results?
richib86
RE: exhaust - cutting our mid silencer and replacing with pi
Post by richib86 » Mon Sep 21, 2009 5:05 pm
i had this on my car for a little while http://www.ecstuning.com/Audi-B7_RS4--V ... S/ES11361/ it was great for what it was but its just not the same as a full exhaust setup
2007 rs4 mugello blue premium package, sirius, black optic grill, miltek non-res non-valved catback, milltek dp's, stasis/alcon clutch, bodymatched reflectors, tints, xenon interior bulbs, KW V3, 10mm h&r spacers, REVO flash, K&N drop in filter, euro steering wheel, jhm short throw,De-Flapped, ac glove mod, IMA multimedia adapter, h-sport sways, some alcantra on the way :)
P_G
Post by P_G » Mon Sep 21, 2009 6:14 pm
Grazer, have a look at this;
http://www.rs246.com/index.php?name=PNp ... hlight=aas
AAS still have the design available should you want to contact them for them to fabricate one and send it to you unless you want to make a trip to Newcastle when they would do the job in a day.
The sound may not be the same as a full exhaust set up but not far off and this way you retain external OEM look plus use of the valves and it is only circa £300 as opposed to a £thousand plus for a full set up.
Sounded good but adding a BMC air filter has helped it sound even better.
P_G
Post by P_G » Mon Sep 21, 2009 6:16 pm
P_G wrote:Grazer, have a look at this;
The sound may not be the same as a full exhaust set up but not far off and this way you retain external OEM look plus use of the valves and it is only circa £300 as opposed to a £thousand plus for a full set up. X-pipes also have slight performance and fuel economy gains.
Grazer_skredge
Post by Grazer_skredge » Mon Sep 21, 2009 8:36 pm
thanks folks - like the look of that.
Our of interest, if I could get a few of these from AAS anyone fancy one ? We can fit them if needed.
GS
poon
Post by poon » Mon Sep 21, 2009 10:20 pm
Grazer_skredge wrote:thanks folks - like the look of that.
GS
yep I would be interested, where are you?
Grazer_skredge
Post by Grazer_skredge » Tue Sep 22, 2009 9:23 am
we're in Loughborough, just off J23 of the M1.
We'll get one of these fitted up to our car first to check fitment then assuming all is good, will post up some details
GS
duud40
Post by duud40 » Wed Sep 23, 2009 6:24 pm
I replaced mid silencers with straight pipes and it`s great. No drone and not too loud.
Users browsing this forum: No registered users and 208 guests
