Bit strange
Bit strange
Bit strange this one. Parked car up at work this morning locked using key fob as usual. When came back this afternoon all four windows were half down car still locked and red light flashing next to door button. Glad it was dry today!
Any ideas? Ran vag com on way back to house and nothing.
Diesel, fuel of the devil!
RE: Bit strange
you must have pressed the key fob button and not realising if it was in your pocket
if you hold the button down it will open up the windows.
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
RE: Bit strange
I agree, ive done this a couple of times. You will also find that it will close any open window when you press and hold down the lock on your key fob. I think you can alter it on vagcom
RE: Bit strange
Holding the unlock button down for a few seconds will indeed open all four windows. BUT, it will also unlock the doors as well. So the only other explanation is that the unlock button was held down for a period of time, released, then the lock button pressed briefly again to lock the doors.
Or, there's a fault somewhere !
RE: Bit strange
If the doors are unlocked and Not opened the doors will lock after a few seconds.
Unit 20
0151 3366888
0151 3366888
Blue_Thunder
- Top Gear
RE: Bit strange
I'm sure i've read about this happening to someone else on here.
- Virdee Autos
- Trader (Expired)
RE: Bit strange
I had this happen to me several times, with no fault codes.
In the end I replaced the siren unit in boot area, and has never occured again.
Don't know if it was a coincidence
Virdee Autos ~ 07950-526592
