Best 235 / 35 / 19s
HTS
Best 235 / 35 / 19s
Post by HTS » Mon Sep 14, 2009 2:22 pm
Need to replace a pair of Michelins, are these still the ones to have or are there better options?
Also these are for the rear, is it OK to mix manufacturers front / rear?
Golffather
RE: Best 235 / 35 / 19s
Post by Golffather » Mon Sep 14, 2009 2:37 pm
IMO mixing front and rears is ok.
In terms of options I'd consider Falken FK452 or Vreds.
jd_hants
Post by jd_hants » Mon Sep 14, 2009 2:45 pm
I had an apparent issue with different tread depths front and rear. rears were new, fronts were 4mm. traction control light used to flash on full throttle in 1st/2nd. seems to have gone now ive replaced the front tyres too. could be a coincidence but in theory the rears would have been large than the fronts marginally so trying the fronts may have been losing traction.
i think tyres having the same profile but from different manufacturers could still have different rolling radiuses???? is so, then mixing front/rear COULD cause the same symptoms I experienced.
Post by HYFR » Mon Sep 14, 2009 3:03 pm
im running Vreds - seem to be one of the best VFM out there
jd_hants
Post by jd_hants » Mon Sep 14, 2009 3:18 pm
Yes same here. But stuck with standard 255's. Might go to 275s next time just to see how different they are now I know they fit ok.
Daveperc
Post by Daveperc » Mon Sep 14, 2009 4:07 pm
Not sure I understand the logic in going down in width - 255 is standard isn't it??
Having tried various:
- PZero - grippy but wore very quickly
- PS2 - very solid, wore well, but pricey
- Dunlop - won't fit at front, but fine on the rear, and wore out quicker than PS2
- Vred's - doing it for me at present - but I have the 275/30 option
Camskill have some good deals on the Vreds at present, and it cost me £9/cornner for my local tyre place to fit and balance. Worth it for all the admiring looks and questions that the car/tyres attracted!
No problem mixing manufactures between front and rear as long as size/profile is the same and wear level is not too different. Must have near identical tyres on each axle though.
SteveCuz
Post by SteveCuz » Mon Sep 14, 2009 4:13 pm
Yeah I think the 235 is a mispost
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
HTS
Re: RE: Best 235 / 35 / 19s
Post by HTS » Mon Sep 14, 2009 6:52 pm
SteveCuz wrote:Yeah I think the 235 is a mispost
Steve
Sorry yes typo - 255!
Do the Vreds have the same "overhang" (can't think of a better word) as the Michelin that prevents a lot of the scuffing of alloys on Kerbs?
Daveperc
RE: Re: RE: Best 235 / 35 / 19s
Post by Daveperc » Mon Sep 14, 2009 7:02 pm
AFIK they have a kerb protector rib on both the 255 and 275's.
See my post on the 275's for a piccie
jd_hants
Post by jd_hants » Tue Sep 15, 2009 8:37 am
Yes my 255s have a kerb protector. Not much but just enough for a slight brush when parking. The 275 might have a bit more.
Daveperc
Post by Daveperc » Tue Sep 15, 2009 9:02 am
I suspect that the protector is the same size on both tyres - but because the 275 is both wider, and squatter, the side wall projects more ensuring the protector doesn't get pushed back by the kerb.
HTS - I have a used pair of PS2's with about 4mm if you want a temporary solution till you need all four doing
HTS
Post by HTS » Tue Sep 15, 2009 11:17 am
Has anyone tried the Avons?
MarkusRS6
Post by MarkusRS6 » Tue Sep 15, 2009 1:49 pm
which type of the Vredestein's are you guys talking about?
2008 Audi RS6 Avant MTM Tuned 702 hp
2009 Nissan GT-R
03 Audi RS6 Saloon Mugello Blue - SOLD
94 Toyota Supra - single turbo 800 hp - SOLD
jd_hants
Post by jd_hants » Tue Sep 15, 2009 1:56 pm
I have Vredestein Ultrac Sessanta XL 96Y 255/35/19.
Users browsing this forum: Majestic-12 [Bot] and 244 guests
