Best 235 / 35 / 19s
HTS
Best 235 / 35 / 19s
Need to replace a pair of Michelins, are these still the ones to have or are there better options?
Also these are for the rear, is it OK to mix manufacturers front / rear?
- Golffather
RE: Best 235 / 35 / 19s
IMO mixing front and rears is ok.
In terms of options I'd consider Falken FK452 or Vreds.
I had an apparent issue with different tread depths front and rear. rears were new, fronts were 4mm. traction control light used to flash on full throttle in 1st/2nd. seems to have gone now ive replaced the front tyres too. could be a coincidence but in theory the rears would have been large than the fronts marginally so trying the fronts may have been losing traction.
i think tyres having the same profile but from different manufacturers could still have different rolling radiuses???? is so, then mixing front/rear COULD cause the same symptoms I experienced.
im running Vreds - seem to be one of the best VFM out there
Yes same here. But stuck with standard 255's. Might go to 275s next time just to see how different they are now I know they fit ok.
Not sure I understand the logic in going down in width - 255 is standard isn't it??
Having tried various:
- PZero - grippy but wore very quickly
- PS2 - very solid, wore well, but pricey
- Dunlop - won't fit at front, but fine on the rear, and wore out quicker than PS2
- Vred's - doing it for me at present - but I have the 275/30 option
Camskill have some good deals on the Vreds at present, and it cost me £9/cornner for my local tyre place to fit and balance. Worth it for all the admiring looks and questions that the car/tyres attracted!
No problem mixing manufactures between front and rear as long as size/profile is the same and wear level is not too different. Must have near identical tyres on each axle though.
Yeah I think the 235 is a mispost
Steve
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
HTS
Re: RE: Best 235 / 35 / 19s
Sorry yes typo - 255!SteveCuz wrote:Yeah I think the 235 is a mispost
Steve
Do the Vreds have the same "overhang" (can't think of a better word) as the Michelin that prevents a lot of the scuffing of alloys on Kerbs?
RE: Re: RE: Best 235 / 35 / 19s
AFIK they have a kerb protector rib on both the 255 and 275's.
See my post on the 275's for a piccie
Yes my 255s have a kerb protector. Not much but just enough for a slight brush when parking. The 275 might have a bit more.
I suspect that the protector is the same size on both tyres - but because the 275 is both wider, and squatter, the side wall projects more ensuring the protector doesn't get pushed back by the kerb.
HTS - I have a used pair of PS2's with about 4mm if you want a temporary solution till you need all four doing
Users browsing this forum: Majestic-12 [Bot] and 195 guests
