S4 misfire when starting from cold
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
yorkie
Post by yorkie » Tue Sep 08, 2009 7:04 pm
Got this today on a mate's B6 platform S4 Cabriolet.
16684 - Random/Multiple Cylinder Misfire Detected
p0300 - 008 - Implausibe Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
p0301 - 008 - Implausible Signal - Intermittent
16689 - Cylinder 5: Misfire Detected
p0305 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3: Misfire Detected
p0303 - 008 - Implausible Signal - Intermittent
16691 - Cylinder 7: Misfire Detected
p0307 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2: Misfire Detected
p0302 - 008 - Implausible Signal - Intermittent
Only happens when starting from cold.
Have looked at Ross Tech Wicki and there are too many possibilities.
Hoping someone has experienced the same.
Any help appreciated.
grizz
RE: S4 misfire when starting from cold
Post by grizz » Tue Sep 08, 2009 7:08 pm
Try running with the maff disconnected ..
Unit 20
0151 3366888
yorkie
Post by yorkie » Tue Sep 08, 2009 8:31 pm
Thanks for the tip mate but I logged the MAF and it was flowing peak of 268 which by using the .8 calculation equates to 335 bhp which considering the temperature I thought looked ok. I am more suspicious of a temp sensor as this only happens around 10 seconds after starting from cold. Have done readiness tests and output tests without finding any problems. I must admit if a sensor was faulty I would have expected a "implausible signal" or "short to ground message" which I haven't got. That then leads me to suspect a mechanical problem such as spark plugs or injectors. Any more suggestions appreciated. Cheers.
baylissboy
Post by baylissboy » Sat Oct 03, 2009 9:35 pm
Does it make any odd rattling noises from cold, i had an similar issue, turned out to be the chain tensioners.
yorkie
Post by yorkie » Sun Oct 04, 2009 8:03 am
Cheers for the reply, I'll have another listen as I don't think he has had it sorted yet.
Return to “DTC / VCDS”
