Got this today on a mate's B6 platform S4 Cabriolet.
16684 - Random/Multiple Cylinder Misfire Detected
p0300 - 008 - Implausibe Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
p0301 - 008 - Implausible Signal - Intermittent
16689 - Cylinder 5: Misfire Detected
p0305 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3: Misfire Detected
p0303 - 008 - Implausible Signal - Intermittent
16691 - Cylinder 7: Misfire Detected
p0307 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2: Misfire Detected
p0302 - 008 - Implausible Signal - Intermittent
Only happens when starting from cold.
Have looked at Ross Tech Wicki and there are too many possibilities.
Hoping someone has experienced the same.
Any help appreciated.
S4 misfire when starting from cold
RE: S4 misfire when starting from cold
Try running with the maff disconnected ..
Unit 20
0151 3366888
0151 3366888
Thanks for the tip mate but I logged the MAF and it was flowing peak of 268 which by using the .8 calculation equates to 335 bhp which considering the temperature I thought looked ok. I am more suspicious of a temp sensor as this only happens around 10 seconds after starting from cold. Have done readiness tests and output tests without finding any problems. I must admit if a sensor was faulty I would have expected a "implausible signal" or "short to ground message" which I haven't got. That then leads me to suspect a mechanical problem such as spark plugs or injectors. Any more suggestions appreciated. Cheers.
Does it make any odd rattling noises from cold, i had an similar issue, turned out to be the chain tensioners.
Cheers for the reply, I'll have another listen as I don't think he has had it sorted yet.
