Secondary Air Injection System - knackered ?
- mattykerby01
Hi Guys,
Think my pump has packed up !
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
Is this a problem ? can i run ok without it ?
Many thanks
Matt
P1423 - 35-00 - -
P1411 - 35-00 - -
Many thanks
Matt
RE: Secondary Air Injection System - knackered ?
Any other info? like has it become noiser recently, has there been any related codes before, have both codes just appeared at the same time? Do you get the EML light on?
You can run fine without it AFAIK, as its only used during warm up anyway, in fact a few RS4 owners have ripped the SAI system out completely.
You can test it out manually even when warm by initiating the SAI pump using by measuring block '76' (if I remember correctly)
I wonder if it's just happened, is there perhaps a seperate fuse for the SAI pump?
- mattykerby01
Yeah, the pump started to get really noisy on start up ! and yes EML on..
So do you think the car will be ok without it ? any tips on stopping the EML ?
Many thanks
Matt
Many thanks
Matt
Deleted my system, no problems
neckarsulm
Mine does that though no MIL.
I am going to crack it and fix it as my pump is new and works well so I suspect the vac pipe from the control valve.
It must be something common to each bank.
Don't you delete guys care about the environment?!
Surely the Euro IV emissions regs that all this cr4p came in because of was drawn up for a reason and not just to fill the time of Brussels bureaucrats and ecomentalists?
Re: RE: Secondary Air Injection System - knackered ?
Nope. Got no cats eitherneckarsulm wrote: Don't you delete guys care about the environment?!
Ooooh, your deffo going to the 'bad fire'!!davs4 wrote:Nope. Got no cats eitherneckarsulm wrote: Don't you delete guys care about the environment?!
RE: Re: RE: Secondary Air Injection System - knackered ?
Yes I will. LOL
are you for real????????????neckarsulm wrote:Mine does that though no MIL.
surely you dont believe in all this global warming BS?
Its all a conspiricy to raise taxes!
neckarsulm
err..no.. that's what theare you for real????????????
- mattykerby01
Hi Guys,
Engine management light keeps coming on with this disconnected, any ideas how to stop it ?
Funny, mine doesnt & I pulled the connector on the air pump on mine. If I vag com for engine faults it shows up then.
Not 100% sure, but I think it will only throw the EML on after a few days (of cold starts), rather than just each time the SAI fault is logged.
