'Squeel' on start up
2.2 I5 20v turbo - 315 bhp
darkhorse1210
Post by darkhorse1210 » Wed Jun 10, 2009 9:06 am
This is probably a very basic Q but not being a mechanic I don't have a clue.
I recently had the main radiator replaced on the RS2 and ever since then the car 'squeels' when you fire her up. Is this anything to do with coolant level or something completely different? The car had a new starter motor about 3k miles ago so shouldn't be that either.
Not causing me any problem it just doesn't sound right.
Ta
AlWyn
Post by AlWyn » Wed Jun 10, 2009 10:16 am
Fan belt possibly?
RS2 s yep ive had a few... it started with a Brilliant Black lhd then a Polar Silver and finally an RS Blau.
alastairg
Post by alastairg » Thu Jun 11, 2009 3:58 pm
Give the belts a quick blast of WD40. If it solves the problem get them changed or adjusted.
VaudiGR
Post by VaudiGR » Thu Jun 11, 2009 10:58 pm
except the camshaft belt. whatever you do,leave that alone
cwill
Post by cwill » Fri Jun 12, 2009 10:51 pm
From having owned older cars in the past and a number from the VAG group, it would sound suspiciously like belts as opposed to starter motor, I would not expect the starter to be squeling as such .....
alastairg
Post by alastairg » Sat Jun 13, 2009 10:07 pm
Vasaudigreece wrote:except the camshaft belt. whatever you do,leave that alone
Agreed but pretty difficult for the novice to get at. Spray the belts you can see :)
darkhorse1210
Post by darkhorse1210 » Mon Jun 15, 2009 9:59 am
alastairg wrote:Give the belts a quick blast of WD40. If it solves the problem get them changed or adjusted.
Ta for that, will give that a go later and let you know if it does the trick, avoiding the canbelt as vas rightly pointed out.
darkhorse1210
Fan Belt was the problem + Air Con sorted
Post by darkhorse1210 » Tue Aug 11, 2009 8:10 pm
AlWyn wrote:Fan belt possibly?
Top marks Al, the fan belt needed tightening, sqeel gone
Having avoided the problem for a while thinking the system was screwed I had the aircon re gassed today and hey presto, it works lovely and it's icy cold, what a relief!
Another problem I sought advice on was the interior blower problem (it only worked on setting III). Turns out it needed a new motor resistor (someone mentioned a rheostat, is that another name for it?). Now works fine on all settings.
Ta for all the advice received on these topics over the last few months, the car is really starting to feel like the car it should be
:P
AlWyn
Post by AlWyn » Wed Aug 12, 2009 10:58 am
Good to hear shes sorted Tom :thumbs:
alastairg
Re: Fan Belt was the problem + Air Con sorted
Post by alastairg » Wed Aug 12, 2009 1:54 pm
If this does not last change 'THE PIPE' that runs from the engine bay top left down thru the wing to the drier. If you search here & S2 forum (thinks its a sticky) the part number will appear
:P
darkhorse1210
Re: RE: Re: Fan Belt was the problem + Air Con sorted
Post by darkhorse1210 » Fri Aug 14, 2009 8:20 am
samsyabi wrote:I too think it is the fan belt.
Audi Q7 2008
Yes, thanks, but having already solved the problem (as per my previous post) I'm struggling to understand the point of your post?
Jusdging by your 10 or so posts to various topics last night I suspect you're either
(a) a clever PC virus
(b) some kid that's managed to register
(c) a bit of a nutter?
Answers on a postcard please :roll:
alastairg
RE: Re: RE: Re: Fan Belt was the problem + Air Con sorted
Post by alastairg » Fri Aug 14, 2009 9:01 am
or english not our first language. Only posting on RS2 section. We will see
AlWyn
Post by AlWyn » Fri Aug 14, 2009 10:23 am
Maybe `not` a good idea to click on the link :wink:
alastairg
Post by alastairg » Fri Aug 14, 2009 12:07 pm
Chips with everything
Users browsing this forum: No registered users and 128 guests
