'Squeel' on start up
darkhorse1210
This is probably a very basic Q but not being a mechanic I don't have a clue.
I recently had the main radiator replaced on the RS2 and ever since then the car 'squeels' when you fire her up. Is this anything to do with coolant level or something completely different? The car had a new starter motor about 3k miles ago so shouldn't be that either.
Not causing me any problem it just doesn't sound right.
Ta
Ta
darkhorse1210
darkhorse1210
Fan Belt was the problem + Air Con sorted
Top marks Al, the fan belt needed tightening, sqeel goneAlWyn wrote:Fan belt possibly?
Having avoided the problem for a while thinking the system was screwed I had the aircon re gassed today and hey presto, it works lovely and it's icy cold, what a relief!
Another problem I sought advice on was the interior blower problem (it only worked on setting III). Turns out it needed a new motor resistor (someone mentioned a rheostat, is that another name for it?). Now works fine on all settings.
Ta for all the advice received on these topics over the last few months, the car is really starting to feel like the car it should be
Re: Fan Belt was the problem + Air Con sorted
darkhorse1210 wrote:Top marks Al, the fan belt needed tightening, sqeel goneAlWyn wrote:Fan belt possibly?
If this does not last change 'THE PIPE' that runs from the engine bay top left down thru the wing to the drier. If you search here & S2 forum (thinks its a sticky) the part number will appear
RS2 'an estate car named Desire'
darkhorse1210
Re: RE: Re: Fan Belt was the problem + Air Con sorted
Yes, thanks, but having already solved the problem (as per my previous post) I'm struggling to understand the point of your post?samsyabi wrote:I too think it is the fan belt.
Audi Q7 2008
Jusdging by your 10 or so posts to various topics last night I suspect you're either
(a) a clever PC virus
(b) some kid that's managed to register
(c) a bit of a nutter?
Answers on a postcard please
RE: Re: RE: Re: Fan Belt was the problem + Air Con sorted
or english not our first language. Only posting on RS2 section. We will see
Users browsing this forum: Google [Bot] and 24 guests
