ESP overly keen.
2.7 V6 30v biturbo - 380 bhp
R5CPK
ESP overly keen.
Post by R5CPK » Fri Jul 03, 2009 9:35 pm
Had my RS4 for a couple of months now. The ESP seems to kick in even when overtaking in a straight line. Don't think this is normal. Had all wheel speed sensors checked and they're fine. Starting to get annoying now. Any ideas??
2003 8L Audi S3
2007 B7 Audi RS4
1998 B5 Audi S4
2004 B6 Audi S4
2000 8L Audi S3
2001 B5 Audi RS4
Stigter
RE: ESP overly keen.
Post by Stigter » Fri Jul 03, 2009 10:04 pm
are all the tyres the same? - recall a post about this a while back
lengster1
Post by lengster1 » Fri Jul 03, 2009 11:54 pm
Hi Craig is it doing it when you flick the car out quickly to overtake and it comes on boost at the same time?If so mine does it too,spirited driving needs it to be turned off really its Poooh
R5CPK
Post by R5CPK » Sat Jul 04, 2009 8:01 am
Yeah all the tyres are the same. Rich , yes it's when you pull out of traffic on an overtake. I expected it when in 2nd or even 3rd as they struggle to put the power down but it's happening in 4th!! Cut's in quite abruptly. Thought maybe I was giving it too much right foot but maybe I just need to get used to it.. or switch it off!!
2003 8L Audi S3
2007 B7 Audi RS4
1998 B5 Audi S4
2004 B6 Audi S4
2000 8L Audi S3
2001 B5 Audi RS4
Nige_RS4
Post by Nige_RS4 » Sat Jul 04, 2009 8:20 am
Could be a broken, dirty or mis-aligned ABS sensor ring too - quite common.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
lengster1
Post by lengster1 » Sat Jul 04, 2009 12:55 pm
Something not right there Craig mine will only do it in the early gears and is running more power,spirited drives do need it to be turned off though even my b7 gets upset and needs to be turned off,audi esp is over sensitive at best as is the abs on b5s
missmouse
Re: ESP overly keen.
Post by missmouse » Tue Jul 07, 2009 10:52 pm
R5CPK wrote:Had my RS4 for a couple of months now. The ESP seems to kick in even when overtaking in a straight line. Don't think this is normal. Had all wheel speed sensors checked and they're fine. Starting to get annoying now. Any ideas??
Mine does exact same!
Im trying to find out if there is some component that could be adjusted/changed/ whatever in the ESP controller ( wherever that might be!)
lushman
Post by lushman » Tue Jul 07, 2009 11:46 pm
My car did it in second and third gear when putting the gas on. The tyres were only slightly more worn on the fron than the rears so I changed the front tyres and the issue stopped for me. This was after having my ABS checked and cleaned.
Hope this helps
Paul
C7 RS6 coming soon
2006 B7 RS4 Avant Sprint Blue & Black Optics - Gone
2000 Avus Silver B5 RS4 - Gone
R5CPK
Post by R5CPK » Tue Jul 14, 2009 10:10 am
lushman wrote:My car did it in second and third gear when putting the gas on. The tyres were only slightly more worn on the fron than the rears so I changed the front tyres and the issue stopped for me. This was after having my ABS checked and cleaned.
Hope this helps
Paul
My rear tyres have more tread than the fronts. Do you think it's worth swapping them around??
2003 8L Audi S3
2007 B7 Audi RS4
1998 B5 Audi S4
2004 B6 Audi S4
2000 8L Audi S3
2001 B5 Audi RS4
derdle
Post by derdle » Tue Jul 14, 2009 10:39 am
Maybe it's the quality of the tyres you are using? When I first had my RS4 I had this trouble, changed the tyres for Michelin PS2s and the problem has never come back.
