Flame Suit On - Another Rolling Road Day
pippyrips
RE: Dyno Trace
Post by pippyrips » Mon Jun 22, 2009 4:53 pm
Well done guys, I guess this helps to prove what some have been saying, you shouldn't read too much into them!
It also proves that the engine is also pretty tunable for a n/a one.
P_G
Post by P_G » Mon Jun 22, 2009 10:51 pm
Managed to get my graph uploaded....
ArthurPE
Post by ArthurPE » Mon Jun 22, 2009 11:34 pm
looks good, very consistent...
look at the ramp rate...the other runs were 10 and 15...not sure if they are the same units...
the car looks starved for air >6000 rpm...
the curve looks identical to the factory curve up until then...
your 90% T point is ~7200 rpm
the factories is 7600
Torque
factory... P_G
4000 RPM
300...304
5000
311...302
6000
314...305
7000
298...283
7500
288...271
factory peak is 5500, yours ~3600
my guess, fans can't supply enough air...
consider: let's say the total intake area is 1 ft^2
at 30 mph ~ 2,640 CFM (just for the intake)
at 60 mph, 5,280
at 100 (4th gear >6000 rpm) ...8800 CFM
can't pressurize the plenum...a bit of boost
velocity pressure ~ 100 MPH ~5" WC ~ 0.17 psi of 'boost'
caldy
Dyno results
Post by caldy » Mon Jun 22, 2009 11:40 pm
Way above my head - but it would account for the fact that my 'inlet system' is considerably modified from stock and that this is significantly responsible for increased power. I need to do some VagCom runs of airflow to see what is going on.
RS4 B7 Phantom Black
pippyrips
RE: Dyno results
Post by pippyrips » Tue Jun 23, 2009 9:29 am
Caldy, when you do mine peaks at around 180g/s with a steady increase all the way up. From memory it peaked at around 165g/s before the manifold work.
Gazzer68
RE: Dyno results
Post by Gazzer68 » Tue Jun 23, 2009 5:01 pm
Not seen mine over 150g/s
07/07 RS4 Avant Mugello Blue
pippyrips
RE: Dyno results
Post by pippyrips » Tue Jun 23, 2009 5:19 pm
What mileage have you done Gazzer? That's low compared to the other cars I have seen.
Gazzer68
RE: Dyno results
Post by Gazzer68 » Tue Jun 23, 2009 5:38 pm
36k
RI_RS4
Post by RI_RS4 » Wed Jun 24, 2009 1:14 am
ArthurPE wrote:looks good, very consistent...
Torque
factory... P_G
4000 RPM
300...304
5000
311...302
6000
314...305
7000
298...283
7500
288...271
at 60 mph, 5,280
This is typical of the engine when timing is being retarded. I've seen this many times on the dyno and VAG runs. If you run full throttle and monitor timing if you're making full power you'll see on a few degrees of <beep>. When the torque bump at 5500 is not there, it's indicative of 5 to 10 degrees of timing pull.
P_G
Post by P_G » Wed Jun 24, 2009 10:31 am
So you think my car's timing is out? It is going in for it's MOT on Monday so I may ask them to look at this if that is the consensus. It has done 50k miles after all so may happen.
RI_RS4
Post by RI_RS4 » Wed Jun 24, 2009 3:32 pm
Timing pull is done automatically by the ECU in response to knock. Sometimes it is due to valve or combustion chamber deposits.
ArthurPE
Post by ArthurPE » Wed Jun 24, 2009 3:47 pm
if the engine is misfiring or 'knocking' you'll get a check light, or at least codes stored...
the fact that it's making rated torque at lower rpm's, and dropping at higher, imo, indicates air flow issues...
could it be deposit related? perhaps...
P_G
Post by P_G » Wed Jun 24, 2009 3:58 pm
It will either be car related airflow or the amount of air fed into the car by the fan, I will maybe ask them to do the VAG-com vacuum airbox flap test.
pippyrips
Post by pippyrips » Wed Jun 24, 2009 4:46 pm
I know when SR71 & myself did some data logging with vagcom prior to the modding I've had done my timing was retarded more than his, and he had better FATS times as a result, even though I had a more consistant flow of air going in. Neither car showed any fault codes.
At 50k you just know what the state of your inlet/valves will be. It could be a number of things but your air flow with definately be affected by the buildup which you will have higher up the rev range.
P_G
Post by P_G » Wed Jun 24, 2009 5:38 pm
Thing is, I use mine on a daily basis and it is motorway commuting so a high degree of airflow and I suspectthat the build up may not be as dramatic as people think. Sure, there will still be deposits but with that much air passing through I wonder if it won't have the chance to accumulatre as mush as say for instance, a car that does a stop start commute or is used for short bursts / weekend toy?
Users browsing this forum: Google Adsense [Bot] and 395 guests
