Flame Suit On - Another Rolling Road Day
RE: Dyno Trace
Well done guys, I guess this helps to prove what some have been saying, you shouldn't read too much into them!
It also proves that the engine is also pretty tunable for a n/a one.
looks good, very consistent...
look at the ramp rate...the other runs were 10 and 15...not sure if they are the same units...
the car looks starved for air >6000 rpm...
the curve looks identical to the factory curve up until then...
your 90% T point is ~7200 rpm
the factories is 7600
Torque
factory... P_G
4000 RPM
300...304
5000
311...302
6000
314...305
7000
298...283
7500
288...271
factory peak is 5500, yours ~3600
my guess, fans can't supply enough air...
consider: let's say the total intake area is 1 ft^2
at 30 mph ~ 2,640 CFM (just for the intake)
at 60 mph, 5,280
at 100 (4th gear >6000 rpm) ...8800 CFM
can't pressurize the plenum...a bit of boost
velocity pressure ~ 100 MPH ~5" WC ~ 0.17 psi of 'boost'
Torque
factory... P_G
4000 RPM
300...304
5000
311...302
6000
314...305
7000
298...283
7500
288...271
at 60 mph, 5,280
Dyno results
Way above my head - but it would account for the fact that my 'inlet system' is considerably modified from stock and that this is significantly responsible for increased power. I need to do some VagCom runs of airflow to see what is going on.
RS4 B7 Phantom Black
RE: Dyno results
Caldy, when you do mine peaks at around 180g/s with a steady increase all the way up. From memory it peaked at around 165g/s before the manifold work.
RE: Dyno results
What mileage have you done Gazzer? That's low compared to the other cars I have seen.
This is typical of the engine when timing is being retarded. I've seen this many times on the dyno and VAG runs. If you run full throttle and monitor timing if you're making full power you'll see on a few degrees of <beep>. When the torque bump at 5500 is not there, it's indicative of 5 to 10 degrees of timing pull.ArthurPE wrote:looks good, very consistent...
Torque
factory... P_G
4000 RPM
300...304
5000
311...302
6000
314...305
7000
298...283
7500
288...271
at 60 mph, 5,280
if the engine is misfiring or 'knocking' you'll get a check light, or at least codes stored...
the fact that it's making rated torque at lower rpm's, and dropping at higher, imo, indicates air flow issues...
could it be deposit related? perhaps...
I know when SR71 & myself did some data logging with vagcom prior to the modding I've had done my timing was retarded more than his, and he had better FATS times as a result, even though I had a more consistant flow of air going in. Neither car showed any fault codes.
At 50k you just know what the state of your inlet/valves will be. It could be a number of things but your air flow with definately be affected by the buildup which you will have higher up the rev range.
Thing is, I use mine on a daily basis and it is motorway commuting so a high degree of airflow and I suspectthat the build up may not be as dramatic as people think. Sure, there will still be deposits but with that much air passing through I wonder if it won't have the chance to accumulatre as mush as say for instance, a car that does a stop start commute or is used for short bursts / weekend toy?
Users browsing this forum: Google Adsense [Bot] and 443 guests
