Re Map, Gruppp M and Miltek?
I have asked a few qustions on here, i am new to the Audi fron after being a M3 CSL man for a few years. Rs4 is next and i am looking at some of the mods people do.
I would like peoples views on the below mods?
Gruppe M Carbon Airbox
Miltek System
Re Map MRC or APS whats the difference?
cheers
Miltek System
cheers
RE: Re Map, Gruppp M and Miltek?
Hello SMD, was you on e36coupe.com, seem to recognise your user name, any way.
I had the same three mods carried out, and overall, I noticed a huge difference in performance.
The GruppeM IMHO, is a good mod, it look good and sounds great, some say the there is n performance benefit and you may even loose power, I personally believe that this is not the case and the engine benefits from more air into the engine *exact opposite to an exhaust.
Milltek, Great, but personally I did not really like the finish of the tail pipes, gains can be had, however some say you will loose back pressure due the the engine being NA (hence why I said the engine will benefit from a GruppeM) I may have opened a can of worms by say this
RE-MAP, again NA engines will NOT benefit much from this unless you have carried out major mods, both MRC and APS do Generic remaps, these are the cheaper type and are still OK, I currently have the APS one, MRC also do a stage 2 Remap, where they will adjust your engine accordingly to the mods you have this takes longer, I booked into MRC for the stage too after I have my pipes and cats fitted.
Again a sensitive topic regarding power loss with the induction system, ppl have had different experiences.
I believe that the M3 CSL lost power when fitted with a Gruppem (confirm) however hard to say really as the OEM induction system on the CSL is very simler to size in the GruppeM cant see how or why it would lose performance, any one clarify on this?
Overall I would say if you was to have the inlet manifold job done and the said mods, they would all compliment each other, as per pippyrips car.
Thanks for the info mate. Yes i am on the CSL register. looks as tho a B7 will be my new car very soon. Just got to find a black. grey or blue
with full spec and low milage!
Re: Re Map, Gruppp M and Miltek?
So did you get yours fix ?SMD wrote:I have asked a few qustions on here, i am new to the Audi fron after being a M3 CSL man for a few years. Rs4 is next and i am looking at some of the mods people do.
Miltek System
cheers
Im thinking of getting the same mod too.
cheers
RE: Re: Re Map, Gruppp M and Miltek?
just trying to understand MRC remapping
is stage I what you need to get if you haven't changed anything else (exhaust for example), and is stage 2 what most people here got, because they had previously installed other custom parts? is that how it works?
also: how would you compare APS generic remap with MRC generic remap (stage I)?
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
CheeRS
MRC stage 2 is a custom map from what i've been able to tell. It takes into account things like aftermarket exhausts and air filters. I can't recommend it enough!
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
so it would be pointless without other custom parts previously installed I presume
CheeRS
CheeRS
Regarding the re-maps. How have people found this affects fuel economy on long runs?
I'm very keen to get above mods at some point and possible re-map. Is it possible to get performance improvement in lower gears whilst maintaining or improving fuel efficiency when cruising in 6th?
I use mine for commuting also so would be reluctant to get the mods and re-map purely for a few extra horses under the bonnet and a bit of extra speed if it has a negative impact on fuel economy..
cheers
cheers
Re: RE: Re: Re Map, Gruppp M and Miltek?
I dont think that's correct - a custom map should be preferable over a generic map most of the time but MRC would be able to tell you for sure - they are pretty helpfulpisquano wrote:so it would be pointless without other custom parts previously installed I presume
RE: Re: RE: Re: Re Map, Gruppp M and Miltek?
They do a generic, custom to fit your mods or the whole nine yards - real time on the road
. Had this on my B5 S4 and it was the dogs. Also improved my fuel economy and sex drive!
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
perfect - will save me a fortune on viagra too!!
what is an estimated all in cost for these 3 mods?
Approx costs for some of the items:
Milltek non-res valved: around £1800 including VAT and fitting
MRC stage 2 remap: around £650 inc. VAT + dyno time
If you're on SW0090 and go for a Milltek then get the 'quiet start mode' with the MRC remap. Your neighbours will appreciate it. My car set off two neighbours' car alarms every time I started it with SW0090 and Milltek. Plus, after I filled up at my local Shell garage a couple of weeks ago, I came back to my car and started it and a people carrier's car alarm at another pump went off. LOL.
I'd also get a decent air filter unless you get one with the Gruppe M airbox.
you mentioned SW0090
is there any merit in checking which software an RS4 has? what are the differences? how do you check it?
CheeRS
CheeRS
SW 90 was to cure rough cold running - I have v 80, which is what all RS4s really should be at least running and no issues with cold running so am not changing to 90.
You can check with VCDS (vag-com) - I wouldn't worry about checking specifically the SW version, in terms of a car purchase
Remember if you have a remap though the 0090 will clear it - as I found out to my shock/horror!
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
