Suspension Again
stenning
Suspension Again
Post by stenning » Wed May 27, 2009 10:13 am
I had the whole of my suspension replaced under warranty; all 4 shocks etc, now found the front 2 are leaking AGAIN and the whole 4 need to be replaced AGAIN. Anyone else had this problem?
Is there a problem with the shocks I don’t know about?
aidanjaye
Post by aidanjaye » Wed May 27, 2009 10:21 am
Emm, type in DRC to the search - should keep you busy reading for a few hours.
sonny
Post by sonny » Wed May 27, 2009 12:36 pm
Bing them and go for the after market suspension, KWv3s seem to be the weapon of choice.
stenning
Post by stenning » Wed May 27, 2009 12:53 pm
May be a good idea as I have been told that I have the modified ones? I would recommend that anyone who has had the shocks changed check them again!!
stenning
Post by stenning » Wed May 27, 2009 4:26 pm
Has anyone negotiated a longer warranty on suspension after having it replaced?
pad125
Post by pad125 » Wed May 27, 2009 4:32 pm
I've read in other threads here that Audi have extended the warranty on the DRC system to 5 years or 80k miles; not been near a dealer lately to confirm but I’m sure if it's been stated here without contest then its gospel
rAudiguy
Post by rAudiguy » Wed May 27, 2009 6:57 pm
You read and hear right my friend but my guess would be only if you ask them about it........ :wink:
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
rjkflyer
Post by rjkflyer » Wed May 27, 2009 8:25 pm
Yes, it's actually 5 years and 75k miles, and applies, as a minimum, to all UK-supplied RS4s.
I have the 'new' parts, having now had 10 shocks i think in total. They appear to be OK so far, and i am becoming convinced that their longevity is related at least partly to the quality of the installation process, which is a bit complicated.
aidanjaye
Post by aidanjaye » Wed May 27, 2009 8:46 pm
Did Audi explain what difference the "new" parts had.
rjkflyer
Post by rjkflyer » Wed May 27, 2009 8:52 pm
I believe it is, on the fronts, a new sealing design and on the rears a new gaiter (or even addition of a gaiter) which should stop crud getting to the (vulnerable obviously) seal.
You would have thought that the 100-year old technology of sealing a shaft was pretty well landed by now. After all, it's not the complexity of the DRC bit that seems to be failing, it's simply the stem seal.
sonny
Post by sonny » Wed May 27, 2009 9:51 pm
if only life was that simple rjkflyer.
RS04COM
Post by RS04COM » Fri May 29, 2009 4:40 pm
The set they replaced mine with had Vasaline smeared just under the top cup. A mechanism to avoid dirt getting in or to stop us seeing the leaks???
Users browsing this forum: Bing [Bot], Google [Bot] and 205 guests
