Suspension Again
Suspension Again
I had the whole of my suspension replaced under warranty; all 4 shocks etc, now found the front 2 are leaking AGAIN and the whole 4 need to be replaced AGAIN. Anyone else had this problem?
Is there a problem with the shocks I don’t know about?
Yes, it's actually 5 years and 75k miles, and applies, as a minimum, to all UK-supplied RS4s.
I have the 'new' parts, having now had 10 shocks i think in total. They appear to be OK so far, and i am becoming convinced that their longevity is related at least partly to the quality of the installation process, which is a bit complicated.
I believe it is, on the fronts, a new sealing design and on the rears a new gaiter (or even addition of a gaiter) which should stop crud getting to the (vulnerable obviously) seal.
You would have thought that the 100-year old technology of sealing a shaft was pretty well landed by now. After all, it's not the complexity of the DRC bit that seems to be failing, it's simply the stem seal.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 116 guests
