What warranty work have you had done?
I am trying to compile a list of potential warranty issues on the B7, would it be possible to post warranty work you have had done here and I will try and compile a full list at the end.
Thanks in advance for your help!
- PetrolDave
RE: What warranty work have you had done?
0080 SW upgrade - that's it.
Re: RE: What warranty work have you had done?
You fib .. what about the Nav disc for TMC ....PetrolDave wrote:0080 SW upgrade - that's it.
RS4 Avant - Sold Aug 2009
RE: Re: RE: What warranty work have you had done?
SW upgrades (which might be warranty work, but certainly not an "issue"), a squeaky seat and DRC
No doubt most people have had something done - unique to them (or a small group) in many cases - and I'm not exactly sure how a list of these would help
Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house...
2007 Daytona RS4 Avant
Thanks, what was the issue with brake discs?
In terms of "Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house..." I think the use will be for owners to check before the cars goes out of warranty, the same as life insurance companies ask for a medical before providing cover, they check the basics not every possible medical problem.
- chrissyr32
Where do you want me to start???
Faulty low break pad sensor
Knackered valve in drivers seat to inflate bolsters
Creaking interior trim "A" pillars.
Corrosion on alumimnuim boot strip
Failed coil pack cylinder 8.
Fuel sensor recall
Battery holder recall.
Loose drivers door handle exterior.
ALL fixed under warranty though never cost me a penny apart from fuel to and from dealers.
BUT i still love this car!!!!!
Fuel sensor recall
- PetrolDave
That wasn't a warranty issue for me - I got hold of the disc from contacts in Europe three months before it was available in the UK.Andyuk911 wrote:You fib .. what about the Nav disc for TMC ....PetrolDave wrote:0080 SW upgrade - that's it.
DRC obviously
front brake disks
engine mounts
couple of recalls - nothing major
Still hoping to get some work done through the warranty at the moment - ECU update for starters...
front brake disks
engine mounts
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
DRC - 2 shock absorbers
Battery holder
New front seat clips
Loose trim in boot
New engine
Battery holder
Loose trim in boot
New engine
DRC - All
Battery tray
Wheel bearing
MAF - Ongoing........
Battery tray
Wheel bearing
RECALL
Fuel sensor recall
ADVISORY
Battery tray advisory (crack in floor)
Power steering fluid change advisory (noisy pump)
0090 sw advisory (major improvement to cold running)
TMC sw update (cos it should work!)
FAILURES
One adaptive xenon replaced on day two of ownership
At least 8 or 10 shock absorbers (now seems OK)
2 coil packs on same cylinder (suspect faulty plug as fault came up and recurred within a month, then gone with new plugs)
Fuel sensor recall
ADVISORY
FAILURES
Users browsing this forum: GhiniRS4 and 126 guests
