Hi all, noob alert. Having minor difficulties with my S4, basically it was leaking boost, found a big hole in the TBB which has now been replaced, all was fine for a while but once again it is cutting boost.
It is coming up with a code, saying that the boost limit is being exceeded intermittantly.
I have pressure tested the inlet system myself and i cannot find another leak, is it possible that the pressure control valve is faulty (n75??)??
any advice appreciated cheers
Niall.
turbo pressure control exceeded?
- niall_wallace
RE: turbo pressure control exceeded?
Re pressure test it. Bet it's a boost leak..
Unit 20
0151 3366888
0151 3366888
Blue_Thunder
- Top Gear
N75's do go faulty. Do you have a boost gauge fitted? Faulty N75's often cause boost spikes which would be easy to see on a gauge.
- niall_wallace
