LOW FAT SPREAD
2.7 V6 30v biturbo - 380 bhp
jimbo1234567
LOW FAT SPREAD
Post by jimbo1234567 » Sun Apr 12, 2009 10:24 pm
thought it was about time i did a few pics and spec..
engine..
rs4 engine
itg air filter
cut out airbox
2.4 heads (standard)
front mount intercooler
710n,s
1.0 comp dropping gaskets
std bottom end
phelonic spacers
ceramic coated mtm ex manifolds
straight rs6 turbos
heat wrapped milltek catless downpipes 2.25"
dual milltek exhaust
tanoga flywheel
uprated helix clutch
side mounted mocal oil cooler
welded up intake-throttle body pipes
boost is about 25 tapering to 22 psi
27 degrees of advance on the timing
the maf was showing 430 gs
9.5x19 mtm wheels
275 30 19 goodyear assymetrics
esp 10mm spacers
h+r fat arbs with mrc strenghening brackets
tanoga short shifter
awe dts bar
dash mounted boost gauge
carbon steering wheel
b7 brakes all round
20 gb phatnoise
laser park pro
roofrack
towbar
tracker
jimbo1234567
RE: LOW FAT SPREAD
Post by jimbo1234567 » Sun Apr 12, 2009 10:25 pm
forgot to mention .. a minhea map
rtd
RE: LOW FAT SPREAD
Post by rtd » Sun Apr 12, 2009 11:45 pm
looks great jimbo - saw the car at Unit20 a while back getting some TLC good to see you up and running again.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
TopBear
RE: LOW FAT SPREAD
Post by TopBear » Sun Apr 12, 2009 11:47 pm
Hubba hubba.
Great spec Jimbo
If you get upto Scotland anytime, give us a shout :thumbs:
You forgot to mention the SAI delete mod as well :wink:
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
FazS3
RE: LOW FAT SPREAD
Post by FazS3 » Mon Apr 13, 2009 12:02 pm
what a lovely looking motor mate!!! awesome!! power must be insane!!
jimbo1234567
Re: RE: LOW FAT SPREAD
Post by jimbo1234567 » Mon Apr 13, 2009 2:46 pm
FazS3 wrote:what a lovely looking motor mate!!! awesome!! power must be insane!!
needs more :twisted:
easto
RE: Re: RE: LOW FAT SPREAD
Post by easto » Wed Apr 15, 2009 5:33 pm
Looks very nice and a top spec. But I was wondering why only 502hp (ONLY he says!!!).
550 Lbft seems a good figure - is this a larger increase over a 460 MTM car in comparison with the HP figures.
I've no idea what torque mine is but this is the key factor. Im guessing it would give a 460 car a good whooping...
I was under the impression that a FMIC could yield 30hp, giving around 490.
yours has the RS6 blowers and other nice little bits and bobs that i presume add HP or keep temps down - so why only 502.
Dont be offended! Im just quite surprised at such small increases and probable expense to eeek out those extra neddys after the initial unleashing via remap and breathing.
OR is that at the WHEELS...in which case - mint!
Misano RS4 (B5), MRC Custom Map , Quick shift, Milltek Exhaust and Downpipes, B7 Front Brakes, B7 19's
dhali
Post by dhali » Wed Apr 15, 2009 6:22 pm
it is WELL known that the MTM figures are a bit enthusiastic :)
easto
Post by easto » Thu Apr 16, 2009 9:40 am
I'm not sure... most RR at similar power levels. And anyway mine was MTM, now MRC remap. Doug indicated it was good for around 460. Never had it rolled though, but even then there are differences between the rollers out there....
Fair point though! I have some rollers about 1 minute from where I live - just never got round to a power run!!
jimbo1234567
Post by jimbo1234567 » Fri Apr 17, 2009 11:37 pm
my car makes arelitively low bhp because the airflow is restricted due to 3 things.
1 intake pipes. still using std k04 intakes as i couldnt get hold of the mrc ones
2 turbo inlets. rs6 turbos use the same size inlet as a k04... mrc usually put a larger inlet on the turbo for more flow
3 downpipes. im using the milltek 2.25" ones instead of the 3"ones that mrc use.
on a turbo car when its being mapped theres always a trade off between boost /timing. more boost =more bhp but that also means you have to have good airflow. if you want torque then you back off the boost and increase the timing instead. looking at the dyno graph lucas posted in another thread of their 592 bhp car my car makes more torque. another thing to add is the wrc rally cars have air intake restrictors to cap the bhp but they make shed loads of torque. hope this helps. jim
jimbo1234567
Post by jimbo1234567 » Fri Apr 17, 2009 11:39 pm
here you go .looks around 530lbft, ish
http://www.rs246.com/index.php?name=PNp ... 0&start=15
easto
Post by easto » Sun Apr 19, 2009 12:37 pm
thanks for the explanation jimbo....overall a nice motor and a spec that would have many drooling! Me included!
easto
Post by easto » Sun Apr 19, 2009 12:47 pm
Whats the car sound like with a ITG panel and cut out air box?
More whistles, turbo sound and genetally boomier?
jimbo1234567
Post by jimbo1234567 » Sun Apr 19, 2009 11:24 pm
the itg filter is just a straight panel replacement and the hole is at the front of the airbox so i dont think anymore noise comes from there although the car does sound like a train.
Users browsing this forum: No registered users and 108 guests
