Custom Code Results and Vag Com Data for Target Boost Vs Act
Joules
RE: Re: RE: Re: RE: Custom Code Results and Vag Com Data for
Post by Joules » Sun Apr 05, 2009 5:17 pm
Definitely needs sorting. Looks like the N75 boost controller which if correct is an easy and relatively cheap fix. Do a log of retardation on each cylinder too.
C63, (C6) RS6 Avant, (C5) RS6 Avant, (B5) RS4 Avant, RS2 Avant, S4, S2, EVO IX 400 BHP
orinoco
Post by orinoco » Sun Apr 05, 2009 5:28 pm
N75 and mafs were replaced December 2008, any other thoughts?
Joules
Post by Joules » Sun Apr 05, 2009 6:06 pm
I still think it is the N75. Simply put the map appears to be asking for less than 1bar boost and the result is a load more which is poorly controlled. Any other opinions all?
Joules
Post by Joules » Sun Apr 05, 2009 6:09 pm
Just check your calculations again to be sure or send me your excel file.
grizz
Post by grizz » Sun Apr 05, 2009 6:29 pm
Like i said joules , the n75 :wink:
Is yours a "west" stage 2 tony???? It was way down on power last year but much better after the maffs & n75.
Best have another look me thinks ...
Unit 20
0151 3366888
orinoco
Post by orinoco » Sun Apr 05, 2009 6:44 pm
Hi Grizz :)
Think they label it a Stage 3 but not the same as other stage 3's think other companies term stage 3 turbo upgrade, West Stage 3 Engine & Gearbox remap full milltek and high flow cat assembly, yeah it was down on power before mafs and n75 and much better after pulling 503 after your fettling
Joules
Post by Joules » Sun Apr 05, 2009 6:46 pm
I think there is a calc problem with your graph, I will post another shortly.
Joules
Post by Joules » Sun Apr 05, 2009 6:49 pm
OK, this is your data and spikes are there but not as bad. DV's??
orinoco
Post by orinoco » Sun Apr 05, 2009 6:56 pm
Thanks Joules, doesn't seem to be running a lot of boost then does it? Grizz did check the dv's when it had the mafs and n75 replaced think he said they were upgraded from original but tthat the 1's on it were still prone to issues with sticking
Joules
Post by Joules » Sun Apr 05, 2009 8:41 pm
Orinoco, better pic
ecain63
Post by ecain63 » Sun Apr 05, 2009 9:02 pm
asd;gadfga;
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
orinoco
Post by orinoco » Sun Apr 05, 2009 10:30 pm
Thanks Joules again, alot easier to see now, chart I selected in Excel for some reason was not plotting correctly, thought boost on standard map ran at about 1 bar? Perhaps Grizz will be along shortly to show me the error of my ways, either way think I need to get the old girl booked in with the Meister to see if the dv's are FUBAR'd and need replacing
Joules
Post by Joules » Sun Apr 05, 2009 10:53 pm
Standard boost is 0.6Bar
el_ringo
Post by el_ringo » Sun Apr 05, 2009 11:49 pm
Hi,
I put my car on the rolling road yesterday and got the following results.
I have the Custom Code Phase 1 remap with standard cats and exhaust. When the map was put on last summer (by Grizz) I had new MAF's, DV's and N75 valve to make the most of it. A service and two new intercoolers also helped.
The run was done immediately after a 4 hour drive so the air intake temperature was sky high (>50oC)
I am very pleased with the torque figure of 560ftlb (760Nm) and I am sure the power of 493 BHP (367Kw) would easily pass 500 with some time to cool the engine bay.
Boost pressure was good, peaking at 1.1 bar and slowly tailing off to about 0.8. It is a shame just under 100 horsies are lost in the transmission.
R
Joules
Post by Joules » Mon Apr 06, 2009 7:25 am
Looks very good!! with an excellent profile for power. Could you post the boost profile too.
Users browsing this forum: Google [Bot] and 208 guests
