Custom Code Results and Vag Com Data for Target Boost Vs Act
Joules
Post by Joules » Fri Apr 03, 2009 7:27 pm
All,
RS6 2004
Following my recent post and RR results showing 440BHP in stock form I have had an Custom Code map. The results are as follows.
I was not happy with the Target Boost Vs Actual Boost results. The boost controller has been changed and there has been an improvement but it is still not perfectly tracking target boost with actuals and there are a few counts of knock retardation. This can be easily provoked with WOT in 3rd lift and then WOT again.
These charts are pre-boost controller fitting and I will post the new actuals shortly.
Opinions welcome, perhaps Boost Duty is set a little aggressive.
C63, (C6) RS6 Avant, (C5) RS6 Avant, (B5) RS4 Avant, RS2 Avant, S4, S2, EVO IX 400 BHP
S2tuner
Trader (Expired)
RE: Custom Code Results and Vag Com Data for Target Boost Vs
Post by S2tuner » Fri Apr 03, 2009 8:53 pm
Ouch, that sort of boost spike won't be doing your gearbox/torque converter/turbos any good!!
ecain63
Post by ecain63 » Fri Apr 03, 2009 9:07 pm
looks like my boost graph with similar results.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
Joules
Post by Joules » Fri Apr 03, 2009 9:08 pm
The first WOT 3rd gear logged run after changing the Boost Controller produced an initial peak of 1.19Bar which is better but still a little over requested. However cracking the throttle open and closed in 3rd with the turbo spooled got a 1.5Bar spike.
What knock retardation is normal on this mod and do you think this is a duty cycle issue?
Joules
Re: RE: Custom Code Results and Vag Com Data for Target Boos
Post by Joules » Fri Apr 03, 2009 9:35 pm
ecain63 wrote:looks like my boost graph with similar results.
Anyone else able to post some plots. Also which Map providers?
FYI, I was able to map a IX EVO to 400BHP with near zero det peak 1.7 and held 1.6 Bar. I am sure this level of control/resolution can be done on an RS6??
ecain63
RE: Re: RE: Custom Code Results and Vag Com Data for Target
Post by ecain63 » Sat Apr 04, 2009 8:46 am
Mine has a cooling issue which is causing the drop off!
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Joules
Post by Joules » Sat Apr 04, 2009 11:03 am
OK plots with the new boost controller are much improved in terms of peak boost control but held is a little low with respect to target. I would recommend always changing the Boost Controller (£37) with a remap.
Also plots in 3rd gear WOT then OFF and repeated WOT.
Much improved knock/retardation as follows. Still would like to see other plots and some advice on normal levels under similar loading. For info becuase it is hard to see level is max 1.5.
orinoco
Post by orinoco » Sat Apr 04, 2009 11:37 am
Are the above plots being generated using Vagcom? If so would be interested to know how as I will go and do some runs and post plots to see how healthy/unhealthy mine is running and of course to provide a comparison
Daveperc
Post by Daveperc » Sat Apr 04, 2009 11:42 am
For the ignorant among us, what is "WOT". I'm guessing "Wellie on Throttle" - or something close!
rs-mad
Post by rs-mad » Sat Apr 04, 2009 12:21 pm
Joules - Do you have a log of a WOT in 3rd from ~3000-redline? Would be interested to see what boost your car is running all the way through
Joules
Post by Joules » Sat Apr 04, 2009 2:30 pm
I am away from my PC so cannot check the specific codes. But yes these are from VagCom measuring boost target and actual. Then I also logged retardation on each cylinder.
WOT = wide open throttle
The plot was done to shift points not redline. The latter not needed because the boost backs off anyway. Just do runs WOT from 3rd 3000 rpm. Then to be sure check with the turbo spooled I.e back off whilst still in 3rd high revs and then WOT again. Then check the same log area for retardation values.
Joules
Post by Joules » Sat Apr 04, 2009 6:20 pm
VagCom settings to log
Revs
G001
Group 1 - Field 0
Engine Speed - (G28)
/min
For all cylinders, this is just 1
G020
Group 20 - Field 0
Timing Retardation - Cylinder 1
°KW
For target boost = value calc ('x' - 1000)/1000 = bar
G115
Group 115 - Field 2
Boost Pressure - (specified)
mbar
For actual boost ('x' - 1000)/1000 = bar
G115
Group 115 - Field 3
Boost Pressure - (actual)
mbar
DavidT
Post by DavidT » Sat Apr 04, 2009 8:45 pm
N75 eh, that's interesting ;)
Joules
Re: RE: Re: RE: Custom Code Results and Vag Com Data for Tar
Post by Joules » Sat Apr 04, 2009 11:03 pm
DavidT wrote:N75 eh, that's interesting ;)
Yep, just proves the worth of VagCom. You could be driving around thinking all is well. I actually had one plot showing 630 ft lbs !!! sounds good but crushing torque for the std box and no good long term.
orinoco
RE: Re: RE: Re: RE: Custom Code Results and Vag Com Data for
Post by orinoco » Sun Apr 05, 2009 2:48 pm
Hmm mine looks unwell based on your first post and yours being unhealthy
