FATS times
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Contigo
FATS times
Post by Contigo » Fri Feb 13, 2009 9:44 pm
Which module and block needs to be logged to calculate FATS times?
Can someone give me a step by step guide of how to calculate?
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
Sebastian
RE: FATS times
Post by Sebastian » Tue Feb 24, 2009 10:32 pm
Don't wanna sound noob'ish, but whats FATS?
Sebastian @ Ross-Tech.com
Contigo
RE: FATS times
Post by Contigo » Wed Feb 25, 2009 4:07 pm
FATS stands for For advancement of the S and is a standard test to measure performance. Involves logging the time it takes to get from 4200rpm to 6500 rpm in third gear using WOT (pedal to metal).
2006 BMW M6 - GONE
neckarsulm
RE: FATS times
Post by neckarsulm » Sat Feb 28, 2009 9:06 am
It's simply a measure of how quickly the car accelerates between 2 defined engine speeds, 4200 rpm and 6500 rpm
So all you need to calculate is TIME STAMP and ENGINE SPEED
Because these cars acclerate so quickly, it's worth getting two time stamp fields and two engine speed fields included in your log so the figure is more accurate as this will halve the time between each data grab and you'll get as close as possible to 4200/6500 on your logs which will help with accuracy.
(it's almost impossible to get VAG COM to catch the data exactly at 4200 & 6500)
Also ideally you need a flat road and you should take the readings in both directions then average the 2.
Link below should help
http://www.mrctuning.com/fatsview.php?c ... t=B5%20RS4
Contigo
RE: FATS times
Post by Contigo » Thu Apr 02, 2009 4:30 pm
Okay so uploaded some runs today to the following site and although I calculated mine manually on the spreadsheet and came up with 3.69s the link following shows different.
http://nyet.org/fats/?image=LOG-01-003-xxx-xxx#result
Is this a good result for a remapped car? Is it running ok?
2006 BMW M6 - GONE
Nige_RS4
RE: FATS times
Post by Nige_RS4 » Thu Apr 02, 2009 4:43 pm
Engine Module & block 003
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Contigo
RE: FATS times
Post by Contigo » Thu Apr 02, 2009 5:06 pm
Yes done it above Nige, please seen results!
2006 BMW M6 - GONE
Nige_RS4
RE: FATS times
Post by Nige_RS4 » Thu Apr 02, 2009 6:59 pm
I did - seems remarkably quick for a stage 2 S4 - do you have an RS4 gearbox? Maybe you should plug the numbers into the mrc FATS calculator?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Blue_Thunder
Re: RE: FATS times
Post by Blue_Thunder » Thu Apr 02, 2009 7:11 pm
Nige_RS4 wrote:I did - seems remarkably quick for a stage 2 S4 - do you have an RS4 gearbox? Maybe you should plug the numbers into the mrc FATS calculator?
It's a Stage 2 RS4 isn't it??
Nige_RS4
Re: RE: FATS times
Post by Nige_RS4 » Thu Apr 02, 2009 7:32 pm
Aah, I see (I sort of scanned the signature and saw B5, assumed it was a B5 S4).
In that case, a stage 2 RS4 should be around 440hp and should be slightly quicker than that? (Stage 2 is remap + catback on the RS4)
My own car is a similar spec but with gutted pre-cats and oem cat-back and can do 3.2 FATS??
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Contigo
RE: Re: RE: FATS times
Post by Contigo » Thu Apr 02, 2009 8:05 pm
Sorry it's not stage 2, it's custom remap which I thought MRC referred to as stage 2, I will amend the sig if wrong.
2006 BMW M6 - GONE
Return to “DTC / VCDS”
