Wheel Alignment
2.7 V6 30v biturbo - 380 bhp
Norrs2
Wheel Alignment
Post by Norrs2 » Thu Apr 02, 2009 12:38 pm
Ok, this is the second set of tyres that are becoming fooked in a year!
1. Had the car tracked by Audi twice since getting the car (one after I was not happy with the slightly offset angle of the steering wheel). It only did about 8k miles before I noticed the very inside of the tyre was seriously bad on a 10 mm strip right on the edge of the tyre. took it back to Audi who said they would have to charge me to check it and that I could have kerbed it or done some kind of damage and it was not they're responsibilty for the tyres wearing out so bad/quickly!
2. I had another recommended establishment set it last year after putting more new tyres on. He used some massive high tech piece of kit with huge hexagonal "clamps" on each wheel. He did adjust it and it definately felt better (Steering Wheel still bang on centre). He advised me to watch tyre pressures and said it should be "ok now"!
Car's been driving very nicely!
Iv'e just checked them and whilst there's plenty of tread 98% accross the tyre, this very very narrow strip on the inside is almost pushing canvas through on both front wheels. they are so far on the inside and the wear so pronounced, that you would swear the car had been driving along with the wheel camber set at 45 degrees?!!!! It just doesn't seem physically possible to get that much wear on the inside when so much tread exists on nearly the whole tyre!
Tyres are not cheap for this car as we all know, but it's really hard to take, that your having to throw them away with 60% of the tread remaining on nearly all of the road contact point.
Does anyone know what the factory camber / toe-in/out settings are so I can make sure that he uses these settings, and does anyone out there know what else could be causing this? The car has never been involved in a prang, so it's not that.
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
Contigo
RE: Wheel Alignment
Post by Contigo » Thu Apr 02, 2009 12:44 pm
I have the same problem and I moved the buckled front to the rear until cash is stronger and it seems to have solved the problem for now.
I really don't understand this problem.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
Norrs2
Re: RE: Wheel Alignment
Post by Norrs2 » Thu Apr 02, 2009 12:47 pm
Contigo wrote:I have the same problem and I moved the buckled front to the rear until cash is stronger and it seems to have solved the problem for now.
Wheels are relatively new (put them on a couple of months after getting the car) and are not buckled! Well not noticed anyway!
I'll keep that in mind though - cheers.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
rickoshea
RE: Re: RE: Wheel Alignment
Post by rickoshea » Thu Apr 02, 2009 5:52 pm
Could you post a picture of the tyre ?
tdiquattro
Post by tdiquattro » Thu Apr 02, 2009 9:44 pm
1BD is the S4 suspension, cheers.
Nige'
2000 silver S4 Saloon
jimbo1234567
Post by jimbo1234567 » Thu Apr 02, 2009 10:02 pm
killing too many evo,s :biggrin2:
tdiquattro
Post by tdiquattro » Thu Apr 02, 2009 10:15 pm
just to add the front camber is not adjustable, it is set by the design of the car, but it has to be balanced out by sliding the whole engine left or right on its sub frame, to get half each side. So it can only be balanced and the value noted.
if your tyre ware is the same on both fronts then i dont think it is that because one would be different?, that only leaves toe in.
Nige'
drjones1
Post by drjones1 » Thu Apr 02, 2009 10:16 pm
jimbo1234567 wrote:killing too many evo,s :biggrin2:
Strange! RS4's (IMO) dont eat tyres, when i had my first one i was doing 30k a year and the tyres were wearing evenly across the tread and lasting circa 20k..
Sounds like a combination of camber and toe. Must admit i have given up with garages and tracking and track my own now.
Its amazing how accurate you can get it with a level surface camber gauge and a role of fishing line..
A8 3.0TDI quattro sport (every day)
B5 RS4 (the second one)
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
Sit on lawn mower (12hp....)
jimbo1234567
Post by jimbo1234567 » Thu Apr 02, 2009 10:18 pm
the subframe alignment is set by lining up 2 holes in the subframe to 2 holes in the chassis at the front of the car. thes are th e same size as a 3/4 socket extension bar. :nogarors4:
tdiquattro
Post by tdiquattro » Thu Apr 02, 2009 10:21 pm
thats just a rough guide when you put the sub frame back in the car, it should then be checked on the alignment settings, it is affected by the top mounts, play in the suspension arm fixings, etc.
Nige'
ollys
Post by ollys » Fri Apr 03, 2009 11:38 am
your car isn't lowered over stock is it by any chance?
Norrs2
Re: RE: Re: RE: Wheel Alignment
Post by Norrs2 » Fri Apr 03, 2009 12:25 pm
rickoshea wrote:Could you post a picture of the tyre ?
Will do, just need to find my cable for the Camera.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Norrs2
Post by Norrs2 » Fri Apr 03, 2009 12:26 pm
ollys wrote:your car isn't lowered over stock is it by any chance?
No ollys, the car is stock height.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Norrs2
Post by Norrs2 » Fri Apr 03, 2009 12:30 pm
@ tdiquattro - Thanks mate, that's a wealth of info :thumbs: Just need to figure out what to do next!!
@jimbo1234567 - "killing too many evo's" - :lol: :lol: PMSL
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
roi354
Post by roi354 » Fri Apr 03, 2009 12:33 pm
So its tracked ok, the camber isn't adjustable, and its not been knocked......
..... Surely there's only bushes left to check :?: :?: :?:
Users browsing this forum: No registered users and 148 guests
