Suspension
2.2 I5 20v turbo - 315 bhp
PHIL_SELF_2
Suspension
Post by PHIL_SELF_2 » Fri Oct 10, 2003 5:05 pm
I don't mind a firm ride (was this a bishop to actress comment or vice versa?), but my suspension, on the car, that is, can best be described as 'clonky' both front & back. The car also seems to want to step out at the rear when it becomes unsettled on bumpy corners. By comparison my wife's A4 Turbo Quattro feels all of a piece over the same route. Any ideas please?
Regards
Phil
P R SELF
DAVIDP20V
Re: Suspension
Post by DAVIDP20V » Fri Oct 10, 2003 7:00 pm
mine is quite a bumpy ride also, but no stepping out unless i want it to [img]images/graemlins/thumbs.gif[/img]
Get audi/specialist to check out the suspension top mounts and bushes i had to have my top mounts changed due to wear before these were done it was very unpredictable. [img]images/graemlins/033102scull_1_prv.gif[/img]
hope this helps a bit [img]images/graemlins/clap.gif[/img]
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
RS2_Russ
Re: Suspension
Post by RS2_Russ » Mon Oct 27, 2003 5:31 pm
Sounds like the dampers may be finished, especially if car is getting out of shape on bump(stop)s. Get some Koni's from qst and the car will be transformed.
01 Goodwood Green RS4. Stage II MRC (460BHP/480lbft).
Audi S8 5.2 V10 Daytona Grey, RS4-type alloys, B&O sound [Gone]
95 Ragussa Green RS2, unmodified and great [Gone]
timucin
Re: Suspension
Post by timucin » Tue Nov 04, 2003 12:43 am
koni or bilstein which one do you think works better?rs2 app.
Quattro
Greg_S
Re: Suspension
Post by Greg_S » Tue Nov 04, 2003 7:28 pm
not much in it, bilsteins are gas shocks so slightly better from performance point of view but arent adjustable and woul have to give it very serious pounding to worry about the oil throthing inside the shock
Bullshit baffles brains
markcanderson
Re: Suspension
Post by markcanderson » Tue Nov 04, 2003 7:39 pm
Doesn't the RS2 from the factory have Bilstein dampers?
'94 Audi RS2 Avant (Polar Silver)
'01 Saab 9-3 TiD S Coupe. (Abbott tuned)
timucin
Re: Suspension
Post by timucin » Wed Nov 05, 2003 12:13 am
i ve checked nothing written on them
Quattro
Jani
Re: Suspension
Post by Jani » Wed Nov 05, 2003 8:09 am
Don't know who produced the originals, but 1.5 years ago the factory replacements were produced by Boge. Otherwise ok, a bit soft in slow movement.
timucin
Re: Suspension
Post by timucin » Wed Nov 05, 2003 12:18 pm
what about coil overs?
anybody using them? they sound pretty nice to me ,adjusting height and softness.
which brand is better/adviced on this type?
thnx
Quattro
Jani
Re: Suspension
Post by Jani » Wed Nov 05, 2003 2:35 pm
Ask Niko at yahoo list. He has K&W coil overs, and is unhappy -they are way too soft. He might even sell those...
Stock suspension is a good compromise IMO. Any lower would have to be rock hard or it is bound to bottom out all the time...
timucin
Re: Suspension
Post by timucin » Wed Nov 05, 2003 8:48 pm
ok;
thnx jani
Quattro
sitas3
Re: Suspension
Post by sitas3 » Wed Nov 05, 2003 8:58 pm
don't know if it helps but I have KW coilovers on my S3 and the springs are a little soft but still harder than the standard springs. I may try and find harder ones if these 'Settle' anymore.
RS2_Russ
Re: Suspension
Post by RS2_Russ » Tue Dec 20, 2011 11:46 am
Hi Guys,
As an ex RS2 owner/lover I know how firm the car was. I now have a B5 RS4, which had similar problems (plus cracked rear springs) to yours and I replaced the complete suspension with a Bilstein/Eibach B12 Kit, which comprises B6/B8 Bilstein dampers, plus matched Eibach springs. The ride is transformed into something (I think) far better than a B7!! No more jiggling/thumping or bumping at all, but not roly-poly at all!!
There is no B12 kit for the RS2, but Bilstein do dampers and I would highly recommend them.
http://web1.carparts-cat.com/default.as ... 004&12=140
Just for info, these are non-adjustable coil-overs, suited to road use, so if you want to slam/track the car they are not for you. For everyday use they will probably be the best money you can spend on the car. For info, the complete B12 kit (springs + dampers) was only £550 delivered.
Russ
(Still missing my Ragussa RS2, even though the RS4 is objectively better)
