best place for an optics grill
Post by HYFR » Mon Mar 16, 2009 9:52 pm
anyone know of anywhere cheaper than here
http://cgi.ebay.co.uk/Genuine-Audi-A6-S ... 240%3A1318
or would it just be cheaper getting it sprayed ?
cheeRS
A20LEE
Re: best place for an optics grill
Post by A20LEE » Mon Mar 16, 2009 10:01 pm
davidkoulakis wrote:anyone know of anywhere cheaper than here
cheeRS
it costs about £6 to spray it yourself.
TopBear
Post by TopBear » Mon Mar 16, 2009 10:32 pm
Agreed. I used a tin of Plastikote to spray mine.
http://www.halfords.com/webapp/wcs/stor ... yId_165495
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Post by HYFR » Mon Mar 16, 2009 10:56 pm
thanks guys
did you spray just the chrome bit or spray it all as its all gonna be black anyhow ?
Corey
Post by Corey » Tue Mar 17, 2009 10:03 am
Black optic grill is only £88.02+VAT for a genuine one, becareful if buying one though as when I bought mine I had about 5 delivered before I found a perfect one, how they are packed from the factory is not good and when they stack them up it leaves a small nick on one of the corners.
Corey
TopBear
Post by TopBear » Tue Mar 17, 2009 10:42 am
davidkoulakis wrote:thanks guys
On my B5 I split the chrome rings and frame away from the grill to paint them seperately.
The grill looked fine with a good clean up.
SpeedSix
Post by SpeedSix » Tue Mar 17, 2009 11:28 am
As above, best thing to do rather than mask is to split the surround from the plastic (you can do this with the badge too)
To get a good key though its best to scotch pad the bits your doing and spray it with a coat of etching primer first. If not you will find the slightest stone chip will take the paint off! I know etching primer is pretty dear but its worth it in the long run! I've still got half a tin of it left if your anywhere near me!
Post by HYFR » Tue Mar 17, 2009 12:21 pm
great advice guys - thanks - I think I will go down the DIY route, via splitting the chrome off. Worst case scenario if I bugger it up is £88+vat
TopBear
Post by TopBear » Tue Mar 17, 2009 1:16 pm
SpeedSix wrote:As above, best thing to do rather than mask is to split the surround from the plastic (you can do this with the badge too)
Speedsix, what's etching primer? I've never heard of it.
David, the grill is very easy to split apart, its basically just a series of clips holding it in place, if its the same (probably) as the RS4 grille.
Post by HYFR » Tue Mar 17, 2009 1:22 pm
question is - is the lower part also "splittable" . . . ?
A20LEE
Post by A20LEE » Tue Mar 17, 2009 1:36 pm
not sure about the RS6 but on the RS4 B5 the surround is coated plastic so i used an acrylic primer so i didn't melt it.
SpeedSix
Post by SpeedSix » Tue Mar 17, 2009 1:50 pm
TopBear wrote: Speedsix, what's etching primer? I've never heard of it.
Etching primer is a primer that eats into the surface of whatever its being sprayed onto to give you a better key! The surrounds and badges are actually plastic but are somehow coated with metal! Dont worry though, the etching primer doesn't eat in as far as the plastic! As I said though its a good idea to give them a light sanding before priming as well to give them an extra key! Especially the badge which is like spraying glass if it isnt prepped properly!
Heres a pic of my spare grill that was done......it never actually made it onto the car, I ended up sticking with standard!
SpeedSix
Post by SpeedSix » Tue Mar 17, 2009 1:52 pm
davidkoulakis wrote:question is - is the lower part also "splittable" . . . ?
I haven't tried but I'm 99.9% sure it will be! Just take your time and you wont crack any of the clips off! :)
Users browsing this forum: Google [Bot] and 213 guests
