best place for an optics grill
anyone know of anywhere cheaper than here
http://cgi.ebay.co.uk/Genuine-Audi-A6-S ... 240%3A1318
or would it just be cheaper getting it sprayed ?
cheeRS
cheeRS
Re: best place for an optics grill
it costs about £6 to spray it yourself.davidkoulakis wrote:anyone know of anywhere cheaper than here
cheeRS
Agreed. I used a tin of Plastikote to spray mine.
http://www.halfords.com/webapp/wcs/stor ... yId_165495
On my B5 I split the chrome rings and frame away from the grill to paint them seperately.davidkoulakis wrote:thanks guys
did you spray just the chrome bit or spray it all as its all gonna be black anyhow ?
The grill looked fine with a good clean up.
As above, best thing to do rather than mask is to split the surround from the plastic (you can do this with the badge too)
To get a good key though its best to scotch pad the bits your doing and spray it with a coat of etching primer first. If not you will find the slightest stone chip will take the paint off! I know etching primer is pretty dear but its worth it in the long run! I've still got half a tin of it left if your anywhere near me!
Speedsix, what's etching primer? I've never heard of it.SpeedSix wrote:As above, best thing to do rather than mask is to split the surround from the plastic (you can do this with the badge too)
David, the grill is very easy to split apart, its basically just a series of clips holding it in place, if its the same (probably) as the RS4 grille.
Etching primer is a primer that eats into the surface of whatever its being sprayed onto to give you a better key! The surrounds and badges are actually plastic but are somehow coated with metal! Dont worry though, the etching primer doesn't eat in as far as the plastic! As I said though its a good idea to give them a light sanding before priming as well to give them an extra key! Especially the badge which is like spraying glass if it isnt prepped properly!TopBear wrote: Speedsix, what's etching primer? I've never heard of it.
Heres a pic of my spare grill that was done......it never actually made it onto the car, I ended up sticking with standard!
