Some advice please
2.2 I5 20v turbo - 315 bhp
Seemo
Some advice please
Post by Seemo » Thu Mar 12, 2009 6:32 am
Hi ,does anyone have experience with Lockheed brake pads for the RS2? Secondly when would be the time to replace suspension bushes and would powerflex bushes be the best option?thanks
DickyC
RE: Some advice please
Post by DickyC » Thu Mar 12, 2009 10:19 am
No advice on the pads, Seemo, but with the bushes I suggest you take the car to one of the specialists and get them to tell you what needs replacing.
Some owners are absolute perfectionists and would advise a complete restoration of the suspension. This is admirable and doubtless very satisfying. When I investigated the costs, however, it was a bit rich for my blood. One of the companies I approached, ACS in Andover, suggested the car didn't need a complete suspension overhaul and replaced just those things that needed replacing.
On the strength of this philosophy, I now treat the maintenance of the whole car using the Forth Bridge analogy: work through it from end to end then start again. The car is back with ACS at the moment for a second look at the bushes. The total cost of both visits will be less than a complete rework.
Original equipment wherever possible is my advice. Others will be along any moment with further comments I feel sure :D
DickyC
Volcano Black 1995 RS2. Standard.
Gone - but understood to be alive and well and living in Cornwall.
Seemo
Post by Seemo » Thu Mar 12, 2009 10:39 am
Thanks for the advice DickyC!
VaudiGR
Post by VaudiGR » Thu Mar 12, 2009 7:15 pm
i would say,get textar pads,which are the best compromise in perfomance and squeel and as far as the bushes are concerned,there are 4 for the front and about 18 for the rear(without counting the subframe ones).
I would say that if you want them to be done once and over with,do it.The fronts get more beating but are easier to replace.The rear ones are more difficult to replace,but the car transforms after that.Mine lasted about 10-13 years so i assume that it is better off replacing them all at once,rather than going fishing to what is damaged or not.
Powerflex are very good,more precise than OEM and make the car more solid.However too solid for my likeing.
alastairg
Post by alastairg » Thu Mar 12, 2009 11:47 pm
Ferodo DS 2500 pads are the beat IMHO. Used EBC & textar over the years.
Suspension OEM. Porsche/Audi did get the best compromise.
RS2 'an estate car named Desire'
Seemo
Post by Seemo » Fri Mar 13, 2009 9:33 am
Thanks for the advice guys..much appreciated.Seemo
Return to “RS2 (B4) 1994-1995”
Users browsing this forum: No registered users and 65 guests
