Any ideas what's rattling at the front of engine when hot?
neckarsulm
My car seem mechanically in good health apart from a weak thermostat and a rattle from the front of the engine when its warm.
It sounds like a classic noisy bearing on one of the pulleys, hard to describe specifically but it sounds similar to the noise a TDI makes at idle but obviously not as loud! I'd say it seems more over to the passenger side than drivers side.
Doesn't seem to be air con related so can rule that out.
It's done 30k since last belt change when it had just 2 tensioners replaced in addition to the water pump and the cambelt itself.
Should anything else have been changed as part of the cambelt change that could be on its way out at 104k miles? I gather auxiliary belt tensioner is one possibility and some sort of idler?
There is a idler on the right side of the engine that drives the viscous fan.
Unit 20
0151 3366888
0151 3366888
neckarsulm
Thanks Grizz, does it do that all the time the engine is running?There is a idler on the right side of the engine that drives the viscous fan.
yes
Unit 20
0151 3366888
0151 3366888
neckarsulm
neckarsulm
Had a look/listen yesterday and it sounds like it's under the timing belt cover on the nearside, is there anything in there that could make that noise?
Got the front bumper off yesterday, well get into 'service position' today.
- Virdee Autos
- Trader (Expired)
Take the aux belt tensioner off, and see that.....more than likely bearings in that will be shot! Although not sure if that will be your cause.
Virdee Autos ~ 07950-526592
neckarsulm
Cheers Virdee.
Got the front off and will investigate tomorrow.
It's never had an aux belt tensioner or probably a few other bits that specialists would change during a service.
Will report back tomorrow.
Good time to sort washer leak, repair & paint bumper, investigate why the horn sounds like its from a 2CV, grease oil cooler unions (one looks a but crusty but dry), do thermostat, secure centre bumper grille, oil change.
- Virdee Autos
- Trader (Expired)
Seems to be the same old common problems
Had to do my centre grille, when I did my cambelt! Pesky stupid clips!
And my horn sounds like 2CV too......they have a high and low tone horn. I'm suspecting one of mine is not working hence the 2CV sound!
neckarsulm
- Virdee Autos
- Trader (Expired)
LOL....!!!
neckarsulm
tensioner, chain, cams??
http://www.MRCtuning.com
Users browsing this forum: No registered users and 99 guests
