Any ideas what's rattling at the front of engine when hot?
2.7 V6 30v biturbo - 380 bhp
neckarsulm
Post by neckarsulm » Sun Mar 08, 2009 7:52 pm
My car seem mechanically in good health apart from a weak thermostat and a rattle from the front of the engine when its warm.
It sounds like a classic noisy bearing on one of the pulleys, hard to describe specifically but it sounds similar to the noise a TDI makes at idle but obviously not as loud! I'd say it seems more over to the passenger side than drivers side.
Doesn't seem to be air con related so can rule that out.
It's done 30k since last belt change when it had just 2 tensioners replaced in addition to the water pump and the cambelt itself.
Should anything else have been changed as part of the cambelt change that could be on its way out at 104k miles? I gather auxiliary belt tensioner is one possibility and some sort of idler?
sherpa
Post by sherpa » Sun Mar 08, 2009 8:08 pm
Other way round for me, i have a rattle i think coming from one of the pulleys but goes when engine gets warm.
grizz
Post by grizz » Sun Mar 08, 2009 8:12 pm
There is a idler on the right side of the engine that drives the viscous fan.
Unit 20
0151 3366888
neckarsulm
Post by neckarsulm » Sun Mar 08, 2009 8:23 pm
Thanks Grizz, does it do that all the time the engine is running?
grizz
Post by grizz » Sun Mar 08, 2009 8:32 pm
yes
Unit 20
0151 3366888
neckarsulm
Post by neckarsulm » Sun Mar 08, 2009 9:11 pm
yes
makes a lot of sense :beerchug:
neckarsulm
Post by neckarsulm » Tue Mar 10, 2009 9:00 am
Had a look/listen yesterday and it sounds like it's under the timing belt cover on the nearside, is there anything in there that could make that noise?
Got the front bumper off yesterday, well get into 'service position' today.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Mar 10, 2009 9:03 pm
Take the aux belt tensioner off, and see that.....more than likely bearings in that will be shot! Although not sure if that will be your cause.
Virdee Autos ~ 07950-526592
neckarsulm
Post by neckarsulm » Tue Mar 10, 2009 9:40 pm
Cheers Virdee.
Got the front off and will investigate tomorrow.
It's never had an aux belt tensioner or probably a few other bits that specialists would change during a service.
Will report back tomorrow.
Good time to sort washer leak, repair & paint bumper, investigate why the horn sounds like its from a 2CV, grease oil cooler unions (one looks a but crusty but dry), do thermostat, secure centre bumper grille, oil change.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Mar 10, 2009 10:18 pm
Seems to be the same old common problems
Had to do my centre grille, when I did my cambelt! Pesky stupid clips!
And my horn sounds like 2CV too......they have a high and low tone horn. I'm suspecting one of mine is not working hence the 2CV sound!
neckarsulm
Post by neckarsulm » Tue Mar 10, 2009 11:26 pm
Must be a noggy thing :nogarors4:
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Mar 10, 2009 11:58 pm
LOL....!!!
imolas4uk
Post by imolas4uk » Thu Mar 12, 2009 12:04 am
run it with the aux belt off and check the noise is still present before you strip the rest :wink:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
neckarsulm
Post by neckarsulm » Thu Mar 12, 2009 8:46 am
Thanks! Hopefully today...
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Mar 12, 2009 10:00 am
tensioner, chain, cams??
http://www.MRCtuning.com
Users browsing this forum: Google Adsense [Bot] and 73 guests
