cam lock tool
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
andybnwc
cam lock tool
Post by andybnwc » Wed Feb 11, 2009 10:17 pm
How much are these ? , i see a few people not using them also is this actually safe?
Mikey-S
RE: cam lock tool
Post by Mikey-S » Wed Feb 11, 2009 10:24 pm
I bought a Laser setting bar from GSF, I think it cost about £40 or so..
It's going to be more accurate using the bar & locking pin, but in my opinion it's going to be safer too because you don't risk one of the pulleys spinning, damaging valves on pistons. In the olden days I used to use Tippex to mark the pulleys, but I don't anymore and certainly wouldn't risk it on one of these engines.
andybnwc
RE: cam lock tool
Post by andybnwc » Wed Feb 11, 2009 10:43 pm
have you still got it?
Mikey-S
RE: cam lock tool
Post by Mikey-S » Wed Feb 11, 2009 10:53 pm
Why? ;-)
jimbo1234567
RE: cam lock tool
Post by jimbo1234567 » Wed Feb 11, 2009 11:48 pm
you can get tippex at any good stationary shop. :thumbs:
andybnwc
RE: cam lock tool
Post by andybnwc » Thu Feb 12, 2009 12:27 am
may be rent it of you, i would use tippex but im sure something would go wrong knowing my luck
imolas4uk
RE: cam lock tool
Post by imolas4uk » Thu Feb 12, 2009 12:44 am
dont use tippex !!,the timing WILL be out after the crank and cams must be locked on these engines to correctly set the valve timing,no-one wants a big bill for a lot of bent valves do they :wink:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Mikey-S
Re: RE: cam lock tool
Post by Mikey-S » Thu Feb 12, 2009 1:19 pm
jimbo1234567 wrote:you can get tippex at any good stationary shop. :thumbs:
Haha! Lol! :D
PM Sent..
Trig
Re: cam lock tool
Post by Trig » Thu Feb 12, 2009 5:03 pm
andybnwc wrote:How much are these ? , i see a few people not using them also is this actually safe?
Where are you?
philipwalker
RE: Re: cam lock tool
Post by philipwalker » Thu Feb 12, 2009 7:02 pm
As suggested above, the cam timing will not be exact if you use paint.
When tensioning the belt you need to crack off the cam pulleys so they are free turning and lock the cams using the correct bar/tool. With the crank locked as well you can tension the belt correctly.
Once you have timed the engine using the correct tools, tighten the cam pulley bolts, remove the pins and bar, turn the engine over on a bar slowly for two rotations. Re-check the timing and it will need to be set again, you may need to do this a few times to get the timing spot on.
Yes, I do sell the correct genuine Audi Cam bar and crank locking pin.
Please call if you need one.
Philip
PW Motorsport Ltd
01437 563793
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=021
http://www.pwmotorsport.com
PW Motorsport
01437 563929
stapo69
Post by stapo69 » Thu Feb 12, 2009 7:12 pm
Contact phoenixmotorsportuk on ebay, he rents them out. Basically you buy the bar off him and them depending how long you keep it he refunds you a percentage of what you paid, 80% for 7 days, 70% for 14. Basically it works out about 20 quid for a week if that.
andybnwc
Re: RE: Re: cam lock tool
Post by andybnwc » Thu Feb 12, 2009 7:31 pm
philipwalker wrote:As suggested above, the cam timing will not be exact if you use paint.
Philip
PW Motorsport Ltd
01437 563793
Didnt realise all this was needed to change timing belt , tensioner,pump and thermostat. If its gonna need all this timing stuff i will have to take it to a garage. :(
stapo69
RE: Re: RE: Re: cam lock tool
Post by stapo69 » Thu Feb 12, 2009 9:08 pm
Gonna cost ya thta is!
andybnwc
Post by andybnwc » Thu Feb 12, 2009 9:59 pm
tell me about it , i was just gonna follow a diy ,will have to have a re think now
Trig
Re: cam lock tool
Post by Trig » Fri Feb 13, 2009 10:39 pm
Where are you?
:roll: :roll: :roll: :roll: :roll: :roll:
Users browsing this forum: No registered users and 125 guests
