Possible clutch on its way out?
2.7 V6 30v biturbo - 380 bhp
mattykerby01
Post by mattykerby01 » Sat Feb 07, 2009 12:25 pm
Hi guys,
After some advise please.
Car seems to be pulling very hard as normal but if at low revs in either 5th or 6th, when floored around 3200 rpm as the boost builds up to peak the revs seem 'race' then settle again.
I am assuming my clutch is on its last legs :cry:
Any suggestions on a replacement, OEM or performance unit ? Bearing in mind my misses drives the car (boost set very low) and dont really want the clutch pedal to be too hard.
Matt
neckarsulm
RE: Possible clutch on its way out?
Post by neckarsulm » Sat Feb 07, 2009 2:00 pm
O.E seems OK unless v. highly tuned.
andream88
Post by andream88 » Sat Feb 07, 2009 2:14 pm
write an e-mail to doug@mrctuning.com, and ask for the Stage1 clutch.
It comes with an OEM pressure plate, and a ceramic/metallic disc.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
mattykerby01
Post by mattykerby01 » Tue Feb 10, 2009 6:02 pm
Written Doug an email and tried to call yesterday and today but no joy......
Has anyone had one fitted? How much did the kit cost?
Contigo
Post by Contigo » Tue Feb 10, 2009 6:18 pm
Got the OEM fitted and it's a big job in terms of labour costs. 10-12 hrs.
About 1500-2000 at Audi Stealers and under a K at Specialist.
I had mine done and the flywheel all in for 1700 notes.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
grizz
Post by grizz » Tue Feb 10, 2009 9:16 pm
It's only 8 hours labour , A new factory exchange clutch is £250ish ...
Unit 20
0151 3366888
Contigo
Post by Contigo » Tue Feb 10, 2009 11:38 pm
Still at a dealer 8 x 120 = 960
parts = 400
You get my drift.
2006 BMW M6 - GONE
LucasRS4
Post by LucasRS4 » Tue Feb 10, 2009 11:43 pm
Send one to info@mrctuning.com or Lucas@mrctuning.com.
Doug is normally busy working on cars!
www.MRCtuning.com
Lucas@mrctuning.com
01295277308
200mph b5 RS4 with towbar - 650bhp/630lbft
grizz
Re: RE: Possible clutch on its way out?
Post by grizz » Tue Feb 10, 2009 11:49 pm
Contigo wrote:Still at a dealer 8 x 120 = 960
parts = 400
You get my drift.
I see your pont , But we're £45 x 8 = £360 + vat ...
Unit 20
0151 3366888
Contigo
RE: Re: RE: Possible clutch on its way out?
Post by Contigo » Wed Feb 11, 2009 3:53 pm
Yes I know you are but my and that's excellent rates but my quote was related to Stealer rates.
2006 BMW M6 - GONE
mattykerby01
Post by mattykerby01 » Wed Feb 11, 2009 7:37 pm
Going for the OEM clutch, which should be good for 500 hp..
Thanks for your help
grizz
Post by grizz » Wed Feb 11, 2009 7:58 pm
The oem is a good unit ....
Unit 20
0151 3366888
mattykerby01
Post by mattykerby01 » Wed Feb 11, 2009 8:22 pm
Cheers grizz
Have you any thoughts on the fly wheel, replacement dual mass or light weight aluminium ?
Do you think i should change the fly wheel, as car now covered 120k miles?
