where to get vag-com from??????????????
HI,im looking to get vag-com i think it will be very useful to me.
is it just the case of getting a lead and downloading the software from somewhere???
or do you have to buy a disc etc??
whats the best/cheapest option to have this on my laptop??
thanks shaun
thanks shaun
RE: where to get vag-com from??????????????
Hi Shaun , I got mine from http://www.ross-tech.com/ .You pay for the cable and then down load the software .
It'll do auto updates for you as well ...
Grizz
Grizz
Unit 20
0151 3366888
0151 3366888
hi grizz,your a great help,thank u.
check the UK distributor list
quicker than buying from the US
http://www.ross-tech.com/distributors.html
- PetrolDave
Second about getting it direct from Ross Tech.
Think about which lead you buy:
1) do you have a USB port on your laptop? Then get a USB lead, when you replace your laptop it almost certainly won't have a serial (RS232) port.
2) do you plan to get a newer VW/Audi/Seat/Skoda at sometime? Then get a HEX-USB+CAN (or HEX-COM+CAN) lead - that will be compatible with your RS6 and all current models too.
thanks very much
Got mine from here, with the current exchange rate probably nearly as cheap as buying from the US.
http://www.gendan.co.uk/category_145.html
^^ me too
good service
good service
Get the HEX-USB-CAN Lead .
Unit 20
0151 3366888
0151 3366888
- PetrolDave
get this one
http://www.gendan.co.uk/product_VCHU.html
by the time you add exchange rate costs and import tax it is the same or cheaper to buy from a UK dealer...
If your looking for a more budget approach...
Just brought a VAG-COM USB cable for the RS4 B5 off wePay £14 (seller gps-ppc). Very prompt delivery, very good support, CD comes with the USB driver and 409.1 from Ross-Tech. I'm using it on a virtiual macine inside VMware Fusion on a Macbook and it works a treat. Car was running limp in 1st gear, scanned the faults, cleared them out, now it's running like a dream again. If your not looking for all the bells and whistles like the newer OEM Ross-Tech versions then this maybe the solution for you. If your based in the Windsor area I'd be happy to give a demo.
Users browsing this forum: No registered users and 36 guests
