SD cards, RNSE and how to make it all work
Right, I have tried searching but to no avail.
I want to buy some SD cards, 4gb, but all I can find are SDHC - Anyone got a link to the correct ones please??
How do I then convert my itunes to MP3 and transfer to the cards - I don't think my laptop has an SD card slot??
Thanks muchly, and sorry for being such a div!
Re: SD cards, RNSE and how to make it all work
Here you go, i use these with no problems at all.OliH wrote:Right, I have tried searching but to no avail.
http://www.mediaprovisions.co.uk/acatalog/SD_Card.html
As for Itunes, can't help sorry
So..OliH wrote:Right, I have tried searching but to no avail.
did you buy the songs off Itunes? or rip them yourself?
If you bought them off Itunes you may have to upgrade to the + DRM free versions to convert them to MP3 (itunes will let you (advanced, create mp3 version))
Then use a USB reader with your SD cards to write the files
A decent deal:-
http://www.play.com/Electronics/Electro ... Promo.html
MIP
Mugello Blue RS4 Saloon
MIP
Or try http://www.mymemory.com for cheap SD cards. Some deals on there will aslo provide you with a free USB2 SD card reader
Like said if downloded i-Tunes you will need the software upgrade, if ripped from CD you can go into the Options tab / menu and select that files are saved in MP3 format rather than IIRC .wav and then they will be read by your RNS-e unit.
This is a link to the ones I ordered:
http://www.stuff-uk.net/?s=ST-TS4GSDC
I got 4 of them and they work perfectly.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
Not that I've done it (and technically I think its illegal), but couldn't you run the files through an "aac2mp3" converter? I think iTunes downloads aac/m4p files?
Would that be cheaper?
FWIW.
FWIW.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Thanks for your help everyone - I have now ordered the cards and reader.P_G wrote:Or try http://www.mymemory.com for cheap SD cards. Some deals on there will aslo provide you with a free USB2 SD card reader
However P G, I can't find this options tab you are on about - Can you enlighten me please
Ta muchly
I'm not on my home PC but IIRC there are tabs at the top next to 'File', one of them may be 'Tools', the select 'Options and under that a central box should appear to allow you to select 'Media Format'
It's a while since I did it and on an old version of i-Tunes so apologies if it has changed a lot but that is a generic guide that should work.
