SD cards, RNSE and how to make it all work
Oli
Post by Oli » Tue Jan 20, 2009 10:16 pm
Right, I have tried searching but to no avail.
I want to buy some SD cards, 4gb, but all I can find are SDHC - Anyone got a link to the correct ones please??
How do I then convert my itunes to MP3 and transfer to the cards - I don't think my laptop has an SD card slot??
Thanks muchly, and sorry for being such a div!
pippyrips
Re: SD cards, RNSE and how to make it all work
Post by pippyrips » Tue Jan 20, 2009 10:24 pm
OliH wrote:Right, I have tried searching but to no avail.
Here you go, i use these with no problems at all.
http://www.mediaprovisions.co.uk/acatalog/SD_Card.html
As for Itunes, can't help sorry :roll:
mip
Post by mip » Tue Jan 20, 2009 11:19 pm
So..
did you buy the songs off Itunes? or rip them yourself?
If you bought them off Itunes you may have to upgrade to the + DRM free versions to convert them to MP3 (itunes will let you (advanced, create mp3 version))
Then use a USB reader with your SD cards to write the files
A decent deal:-
http://www.play.com/Electronics/Electro ... Promo.html
MIP
Mugello Blue RS4 Saloon
P_G
Post by P_G » Wed Jan 21, 2009 4:10 pm
Or try http://www.mymemory.com for cheap SD cards. Some deals on there will aslo provide you with a free USB2 SD card reader
Like said if downloded i-Tunes you will need the software upgrade, if ripped from CD you can go into the Options tab / menu and select that files are saved in MP3 format rather than IIRC .wav and then they will be read by your RNS-e unit.
bn8959
Post by bn8959 » Wed Jan 21, 2009 7:26 pm
This is a link to the ones I ordered:
http://www.stuff-uk.net/?s=ST-TS4GSDC
I got 4 of them and they work perfectly.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
SR71
Post by SR71 » Wed Jan 21, 2009 7:43 pm
Not that I've done it (and technically I think its illegal), but couldn't you run the files through an "aac2mp3" converter? I think iTunes downloads aac/m4p files?
Would that be cheaper?
FWIW.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Oli
Post by Oli » Wed Jan 21, 2009 8:29 pm
P_G wrote:Or try http://www.mymemory.com for cheap SD cards. Some deals on there will aslo provide you with a free USB2 SD card reader
Thanks for your help everyone - I have now ordered the cards and reader.
However P G, I can't find this options tab you are on about - Can you enlighten me please
Ta muchly
P_G
Post by P_G » Wed Jan 21, 2009 8:33 pm
I'm not on my home PC but IIRC there are tabs at the top next to 'File', one of them may be 'Tools', the select 'Options and under that a central box should appear to allow you to select 'Media Format'
It's a while since I did it and on an old version of i-Tunes so apologies if it has changed a lot but that is a generic guide that should work.
Oli
Post by Oli » Wed Jan 21, 2009 8:56 pm
Sorry P G, thats not on my itunes........
Someone help!
SR71
Post by SR71 » Wed Jan 21, 2009 9:03 pm
Select songs, right click and select "Convert to MP3" option...
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Oli
Post by Oli » Wed Jan 21, 2009 9:08 pm
i am officially thick, if I right click a song in itunes it doesn't have that option
SR71
Post by SR71 » Wed Jan 21, 2009 9:12 pm
What version of iTunes do you have?
I'm using 7.6.2.9
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
P_G
Post by P_G » Wed Jan 21, 2009 9:15 pm
When you are in your song list, select a song, right click and select 'Create MP3 version'
Also for future imports;
Go to 'Edit'
Select 'Preferences'
Click on 'Import Settings' Tab
Select 'MP3 Encoder' on the 'Import Using' drop down list.
Click 'OK' and 'Ok' and you are done.
Oli
Post by Oli » Wed Jan 21, 2009 9:18 pm
Mine only has create AAC version???
Is that the same?
P_G
Post by P_G » Wed Jan 21, 2009 9:24 pm
I don't think so, perhaps do the set up as indicated first and it then might give you the option.
Users browsing this forum: Google [Bot] and 240 guests
