Knocking noise when manouvering
My car has an intermittent knocking noise from the front when on full right lock at parking speeds.Bizarrely this only occurs when it is wet!
The dealer has looked at it three times ,the first two occasions they could not find anything. On the last visit they replaced a defective cv joint . Unfortunately this has not helped.
Does anyone have any ideas.
I had a repetitive "ticking" noise when making left turns...from the front right hand corner.
Initially Audi replaced lower-drag links which cured the problem...temporarily.
It re-appeared about 6 months later and a one new wheel bearing later, its gone again.
I'm waiting for it to re-surface!
However, when you say, "knocking", I hazard a guess its not the same noise...
Its not the old "graunching" noise which you get at full lock which is a function of the low profiles and the inability of the respective rubber to move across the ground smoothly at such tight radii of curvature....
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
I have had the same problem on both sides 4 or 5 times wet & dry conditions, each time they replaced the CV joint which seemed to help for a short while. The car was in last week for the same problem but they failed to rectify the problem again. It now looks like they don't know what to do and have said their isn't a problem
I will be speaking with Audi UK this week, i will post any feed back.
SwedishRS4
- PetrolDave
RS4Phantom2007
Can someone expand on the "graunching" noise please.SR71 wrote:I had a repetitive "ticking" noise when making left turns...from the front right hand corner.
I'm unsure if I'm possibly suffering this or if it's a more serious problem
It's on a 2007 A4 S-line with 235/40 R18 tyres.
Was going to say exactly the same myself (although I didn't have an S4 before my A4 - just one after, but before my RS4!)PetrolDave wrote:My RS4 does it, my S4 before it did it, my A4 before that did it and my S4 before that did it.... they DO all do it (at least that's my experience).
2007 Daytona RS4 Avant
Same here; developed the 'quirk' when my last set of tyres were low but was cured as soon as the new boots went on. Started to develop the same thing now as the tyres are on the way out.ste4ie wrote:Have had the same problem on my S4, but only when front tyres are down to about 1.8mm then once tyres replaced (with same tyres) the noise dissapears until the tyres wear down again. This has happened on 2 sets of front tyres now.
Just my thoughts and probably not everyones problem.
Users browsing this forum: Zyox and 241 guests
