Problems connecting Parrot Bluetooth to RNS-E
mrdeli
Post by mrdeli » Sun Dec 21, 2008 7:27 pm
Hi there - I am having real problems with the above.
I have got eveything working, but when I use the Parrot only the front upper speakers mute.
The rear speakers and I think the front lower ones continue to work.
Is it just a case that I need to connect a mute wire - if so where does it connect to.
My car is a A4 - 57 Reg (B7) - with RSN-E nav but NO bose.
Many thanks for any help. Mark
dubwhizz
RE: Problems connecting Parrot Bluetooth to RNS-E
Post by dubwhizz » Mon Dec 22, 2008 10:30 am
is it parrot 3200? if so there will be three mute wires in the loom. you need to monitor which one goes low and hook it up to the back of the unit.
post a pic of the loom, might be able to describe it better.
Matt
mrdeli
Post by mrdeli » Mon Dec 22, 2008 10:40 am
Thanks Matt - I have located the mute wire from the Parrot (yes 3200) - but am unsure where (what pin) I connect to on the RNS-E system.
Thank you for your help.
Regards, Mark
PetrolDave
Re: RE: Problems connecting Parrot Bluetooth to RNS-E
Post by PetrolDave » Mon Dec 22, 2008 3:09 pm
mrdeli wrote:Thanks Matt - I have located the mute wire from the Parrot (yes 3200) - but am unsure where (what pin) I connect to on the RNS-E system.
Connect it to the pin called Tel Mute (look on the label on the top of the RNS-E for the pin number).
craigyb
RE: Re: RE: Problems connecting Parrot Bluetooth to RNS-E
Post by craigyb » Mon Dec 22, 2008 4:16 pm
Pin 11 of connector D
mrdeli
Post by mrdeli » Fri Jan 02, 2009 11:01 pm
Thank you very much for all your help - great forum, as always ;@)
Return to “Electrical”
Users browsing this forum: Majestic-12 [Bot] and 22 guests
