Rear calipers serviceable?
Can you get a service kit for the rear calipers? I suspect one of mine has a lazy handbrake mechanism and presume i will have to pop out the piston to get at the ratchet set up?
- Virdee Autos
- Trader (Expired)
RE: Rear calipers serviceable?
The only service kit is the caliper seals, which consists of two seal for each caliper. One for the outer protective boot, and one seal inside the caliper.
Virdee Autos ~ 07950-526592
Thanks Virdee has anyone here ever stripped one? Can it be done?
Any caliper can be stripped , a new one is about £150 from audi .
Unit 20
0151 3366888
0151 3366888
- Virdee Autos
- Trader (Expired)
Take the caliper off the car, unscrew the piston. Replace both seals, check for any damage...clean associated parts, and put back together. Bleed the system, and check correct operation.
I think you'll find quite a few B5's have split rear caliper seals. Got to do my own ones when I get time!
- boxerdogted
As long as the chrome hasn't started to come of the piston you wont have a problem.
2001 RS4 Misano Red
Ok guys if its the piston thats sticking and a standard overhaul thats no probs at all,i was thinking it was the handbrake mechanism and wasnt sure if it was stripable,will pop the piston out in the morning and take it from there,thanks guys
I've never serviced a rs4 rear caliper , What happens with other hand brake calipers is the shaft that corrodes that links the arm to the internal screw thread . This can some times be cleaned up but it will go again as the chrome has gone.
Unit 20
0151 3366888
0151 3366888
Hmm thanks grizz thats kinda what im expecting when i strip the caliper,If the calipers goosed do you have one by any chance? How much are you doing b7 front calipers and pads for out of interest?
Where do we get the caliper service kit from?
- Virdee Autos
- Trader (Expired)
Available from Audi.
Re: RE: Rear calipers serviceable?
Do you know the part number?Virdee Autos wrote:Available from Audi.
RE: Re: RE: Rear calipers serviceable?
Im off to pick it up shortly will let you know
Ive just ordered a set, £12 something each
Re: RE: Re: RE: Rear calipers serviceable?
Part number please?bneaves wrote:Ive just ordered a set, £12 something each
Users browsing this forum: Google Adsense [Bot] and 77 guests
