Rear calipers serviceable?
2.7 V6 30v biturbo - 380 bhp
lengster1
Post by lengster1 » Sun Dec 14, 2008 5:47 pm
Can you get a service kit for the rear calipers? I suspect one of mine has a lazy handbrake mechanism and presume i will have to pop out the piston to get at the ratchet set up?
Virdee Autos
Trader (Expired)
RE: Rear calipers serviceable?
Post by Virdee Autos » Sun Dec 14, 2008 6:17 pm
The only service kit is the caliper seals, which consists of two seal for each caliper. One for the outer protective boot, and one seal inside the caliper.
Virdee Autos ~ 07950-526592
lengster1
Post by lengster1 » Sun Dec 14, 2008 6:22 pm
Thanks Virdee has anyone here ever stripped one? Can it be done?
grizz
Post by grizz » Sun Dec 14, 2008 6:38 pm
Any caliper can be stripped , a new one is about £150 from audi .
Unit 20
0151 3366888
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sun Dec 14, 2008 6:56 pm
Take the caliper off the car, unscrew the piston. Replace both seals, check for any damage...clean associated parts, and put back together. Bleed the system, and check correct operation.
I think you'll find quite a few B5's have split rear caliper seals. Got to do my own ones when I get time!
boxerdogted
Post by boxerdogted » Sun Dec 14, 2008 7:56 pm
As long as the chrome hasn't started to come of the piston you wont have a problem.
2001 RS4 Misano Red
lengster1
Post by lengster1 » Sun Dec 14, 2008 9:55 pm
Ok guys if its the piston thats sticking and a standard overhaul thats no probs at all,i was thinking it was the handbrake mechanism and wasnt sure if it was stripable,will pop the piston out in the morning and take it from there,thanks guys
grizz
Post by grizz » Sun Dec 14, 2008 10:03 pm
I've never serviced a rs4 rear caliper , What happens with other hand brake calipers is the shaft that corrodes that links the arm to the internal screw thread . This can some times be cleaned up but it will go again as the chrome has gone.
Unit 20
0151 3366888
lengster1
Post by lengster1 » Sun Dec 14, 2008 10:14 pm
Hmm thanks grizz thats kinda what im expecting when i strip the caliper,If the calipers goosed do you have one by any chance? How much are you doing b7 front calipers and pads for out of interest?
bneaves
Post by bneaves » Fri Dec 19, 2008 2:21 pm
Where do we get the caliper service kit from?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Dec 19, 2008 7:30 pm
Available from Audi.
dace
Re: RE: Rear calipers serviceable?
Post by dace » Sat Dec 20, 2008 9:29 am
Virdee Autos wrote:Available from Audi.
Do you know the part number?
Dave
lengster1
RE: Re: RE: Rear calipers serviceable?
Post by lengster1 » Sat Dec 20, 2008 1:37 pm
Im off to pick it up shortly will let you know
bneaves
Post by bneaves » Sat Dec 20, 2008 2:56 pm
Ive just ordered a set, £12 something each
dace
Re: RE: Re: RE: Rear calipers serviceable?
Post by dace » Sat Dec 20, 2008 6:33 pm
bneaves wrote:Ive just ordered a set, £12 something each
Part number please?
Dave
