18 months on and I'm back with another :)
2.7 V6 30v biturbo - 380 bhp
Overlord
Post by Overlord » Fri Dec 05, 2008 9:56 pm
Hi All,
Back around xmas 2006 i bought my first RS4, loved it but for many reasons had to sell. Now after a short and boring (car wise) leave i am back, another child in the ranks and definately in need of an estate. So i found and bought an Avus Silver avant on a Y plate. I must say i have missed the power and ride quality.
I am having some issues with it though and perhaps someone can help.
The car is 100% stock, sometimes it goes like a scalded cat, others it seems to have little or no boost, i have used the search button and sort or narrowed it to either MAF, DV's sticking or perhaps and EGT sensor gone, i dont have access to VAGCOM, anyone in the West Midlands that has?? and have i missed something thats obvious.
Also are there any independents in the West Mids?
Its nice to be back :)
Virdee Autos
Trader (Expired)
RE: 18 months on and I
Post by Virdee Autos » Fri Dec 05, 2008 10:11 pm
Your symptoms make it sound like a EGT sensor. Could be MAF, but doubt that would make it intermmitent.
Good to hear your back with another B5! Enough said!
Virdee Autos ~ 07950-526592
mikeyquattro
Post by mikeyquattro » Fri Dec 05, 2008 10:19 pm
Sounds like its dropping into limp mode. Get down to MRC to get it checked out and repaired (and remapped!)
Tomorrow is another day
Overlord
Post by Overlord » Fri Dec 05, 2008 10:35 pm
Thanks for that. The engine check passes as OK, but i guess it can still log a DTC. I will speak to a pal who may have access to VAGCOM.
frazered
Post by frazered » Fri Dec 05, 2008 11:17 pm
check this thread
http://www.rs246.com/index.php?name=PNp ... ic&t=51359
plenty of people with vag.com who would help
Overlord
Post by Overlord » Sat Dec 06, 2008 12:15 am
Brilliant, thanks :)
jimbo1234567
Post by jimbo1234567 » Sat Dec 06, 2008 12:28 am
new dvs maf and n75, then check to see which egts and lambdas have been killed. simple
rs4raz
Re: 18 months on and I'm back with another :)
Post by rs4raz » Sat Dec 06, 2008 3:31 am
Overlord wrote:Hi All,
i have the same problem with mine sometimes it has no boost at all and most of the time it goes how it should! keep ur results posted, will be interesting to know.
Silversea
RE: Re: 18 months on and I
Post by Silversea » Sat Dec 06, 2008 8:48 am
A friend had this with his B5 S4 and it turned out to be sticking wastegates on the turbos.
Only fix was replacement of the turbos.....
Just can't get the smile off my face......
Overlord
Post by Overlord » Sat Dec 06, 2008 10:17 am
GULP!............
I do have a very good warranty though :)
Whats an N75?
jimbo1234567
Post by jimbo1234567 » Sat Dec 06, 2008 8:49 pm
its an electric valve that controlls boost, if it snot working right then you at worst will only be running around 7psi which is the actuator pressure. change those 4 parts and the car will fly.promise :lol:
Overlord
Post by Overlord » Sat Dec 06, 2008 8:57 pm
jimbo1234567 wrote:its an electric valve that controlls boost, if it snot working right then you at worst will only be running around 7psi which is the actuator pressure. change those 4 parts and the car will fly.promise :lol:
I have found a local indy and will be booking it in next week, i take it the N75 is basically a re named boost control solenoid then.
Thanks for the advice :)
jimbo1234567
Post by jimbo1234567 » Sun Dec 07, 2008 1:48 am
yep. a fish tank valve , in old speak. too bleed boost pressure off thus fooling the actuators :biggrin3:
rs4raz
Post by rs4raz » Sun Dec 07, 2008 2:39 am
so if it is the n75 causing the boost to come and go will it show on vag com
Overlord
Post by Overlord » Sun Dec 07, 2008 10:27 am
rs4raz wrote:so if it is the n75 causing the boost to come and go will it show on vag com
I would guess not unless theres a sensor that monitors it. The Volvo's suffer with these too and i have seen a few blown engines, so as a matter of course i will change it. I guess they are under £80 anyway.
Thanks for the help guys, its appreciated.
