fluctuating water temperature gauge....
2.7 V6 30v biturbo - 380 bhp
rhunter203
Post by rhunter203 » Wed Nov 19, 2008 3:41 pm
The water temperature needle rising between 75 and 90. The needle normally sits in the middle on 90. Any ideas??? Maybe the thermostat is knackered??
Rob
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
Sql_RS4
Post by Sql_RS4 » Wed Nov 19, 2008 4:37 pm
Happened to me too.
You need to change water temp sensor.
boxerdogted
Post by boxerdogted » Wed Nov 19, 2008 8:47 pm
Try the sensor first, mine was the thermostat in the end.
2001 RS4 Misano Red
S4INT
Post by S4INT » Wed Nov 19, 2008 10:56 pm
Yep - thermostat I'm afraid. Big job as the cambelt/water pump etc has to come off.
Try the sensor first as its cheap and easy to do, but I have had these symptoms on both my B5's and both times it was changing the thermostat that cured it.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
rhunter203
Post by rhunter203 » Thu Nov 20, 2008 12:32 pm
Cheers guys!!!
3.6 0-60 12.04 1/4M
polly_x
Post by polly_x » Sun Nov 23, 2008 1:06 pm
Does the green temp sensor feed just the gauge on the dash or does it also give the engine management its water temp too? (or is there another separate sensor for the ECU)
Stu
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sun Nov 23, 2008 4:25 pm
Yep the green 4 pin sensor does work with the engine management aswell.
Virdee Autos ~ 07950-526592
polly_x
Post by polly_x » Mon Nov 24, 2008 3:31 pm
Virdee Autos wrote:Yep the green 4 pin sensor does work with the engine management aswell.
Cheers.
So if the sender is faulty (vagcom says it is) the dash dont work and I guess the ECU is seeing the wrong signal or that the car is stone cold all the time? It still runs really nice which is odd as I thought it would have at least some effect on the mapping.
Will change it tonight then as ive had a new one on the garage for 2 weeks now!
Any links to guides on how to do it on here? Or is it just a simple remove covers and what else?
Ta
s4-99
Post by s4-99 » Mon Nov 24, 2008 4:19 pm
Have a read of this...This is for an S4 but i presume it's the same for the RS4
http://www.rs246.com/index.php?name=PNp ... torder=asc
3rd post down tells you how to change it...
Hmmm, its fast but is it fast enough!!!
SimonC
Post by SimonC » Mon Nov 24, 2008 4:20 pm
Had mine done under warranty last year (went to open circuit during warm-up. Vag-com is brill!) Only advice I can offer is that the technician bled on my engine so beware of sharp edges.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Nov 24, 2008 8:06 pm
Yes this also controls the temp gauge in the instrument cluster
After you've changed it you'll notice the car is more responsive
Blue_Thunder
Post by Blue_Thunder » Mon Nov 24, 2008 9:31 pm
I believe two pins send a signal to the cluster and the other tow pins send a signal to the ECU.
When my temp gauge started playing up it would just drop off the scale. Using the Climate Control to check the temp being sent to the ECU showed that it was still sending 90 to the ECU. Turned out to be a split wire on the sensor, but replaced it anyway with it only costing about a tenner.
Users browsing this forum: No registered users and 152 guests
