fluctuating water temperature gauge....
- rhunter203
The water temperature needle rising between 75 and 90. The needle normally sits in the middle on 90. Any ideas??? Maybe the thermostat is knackered??
Rob
Rob
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
3.6 0-60 12.04 1/4M
- boxerdogted
Yep - thermostat I'm afraid. Big job as the cambelt/water pump etc has to come off.
Try the sensor first as its cheap and easy to do, but I have had these symptoms on both my B5's and both times it was changing the thermostat that cured it.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
- rhunter203
- Virdee Autos
- Trader (Expired)
Yep the green 4 pin sensor does work with the engine management aswell.
Virdee Autos ~ 07950-526592
Cheers.Virdee Autos wrote:Yep the green 4 pin sensor does work with the engine management aswell.
So if the sender is faulty (vagcom says it is) the dash dont work and I guess the ECU is seeing the wrong signal or that the car is stone cold all the time? It still runs really nice which is odd as I thought it would have at least some effect on the mapping.
Will change it tonight then as ive had a new one on the garage for 2 weeks now!
Any links to guides on how to do it on here? Or is it just a simple remove covers and what else?
Ta
Have a read of this...This is for an S4 but i presume it's the same for the RS4
http://www.rs246.com/index.php?name=PNp ... torder=asc
3rd post down tells you how to change it...
Hmmm, its fast but is it fast enough!!!
- Virdee Autos
- Trader (Expired)
Yes this also controls the temp gauge in the instrument cluster
After you've changed it you'll notice the car is more responsive
Blue_Thunder
- Top Gear
I believe two pins send a signal to the cluster and the other tow pins send a signal to the ECU.
When my temp gauge started playing up it would just drop off the scale. Using the Climate Control to check the temp being sent to the ECU showed that it was still sending 90 to the ECU. Turned out to be a split wire on the sensor, but replaced it anyway with it only costing about a tenner.
Users browsing this forum: No registered users and 62 guests
