275/35/19
peterpan
Post by peterpan » Sun Oct 26, 2008 2:36 pm
Hi, everybody
has everone ever tried 275/35/19 size? On our roads is important the sideheight. It looks not too bad:
Pete
PetrolDave
RE: 275/35/19
Post by PetrolDave » Sun Oct 26, 2008 3:05 pm
I think the increase in overall diameter of 14mm could cause rubbing issues. The 275/30x19s come much closer to the wheelarches than the 255/35x19, and I think you might find the 275/35x19 might actually touch the wheelarches.
rjkflyer
RE: 275/35/19
Post by rjkflyer » Sun Oct 26, 2008 9:34 pm
Well, given the width is the same, then this rubbing issue would only be down to the amount of suspension travel?
Bit worrying for anyone with 275's full stop - so are you sure this will cause an issue?
I thought that the 275's were 100% OK re rubbing, UNLESS you used spacers, and even then it seemed 10mm was still OK on the rear and 8mm on the front, but i will defer to those who have used them.
tartan_rob
RE: 275/35/19
Post by tartan_rob » Mon Oct 27, 2008 10:25 am
I have done about 20k on 275's with NO issue whatsoever. Apart fromt he extra grip....
2017 Kawasaki Z1000
2014 RS6
2014 S1
mac4RS
RE: 275/35/19
Post by mac4RS » Mon Oct 27, 2008 10:59 am
Same here...7k with a track day & plenty of grip :)
hussains
RE: 275/35/19
Post by hussains » Mon Oct 27, 2008 1:52 pm
I have had it changed to the 275/30/19.....I seem to be getting a light vibration at high speeds. Have had the balancing done twice. I am not sure if this is what is expected or the tyre company just cant get it right?
PetrolDave
RE: 275/35/19
Post by PetrolDave » Mon Oct 27, 2008 2:17 pm
peterpan is talking about 275/35's and NOT the 275/30s that we are all running...
I'm running the 275/30's myself with no problems at all even when fully loaded with wine after a trip to the Loire - but if you look at the attachment in peterpan's post you will see that the diameter of the 275/35's is 14mm BIGGER than the OE fit 255/35's but the 275/30's that we have is 23mm LESS.
So the 275/35s will have a 37mm greater diameter than we have - I'm almost certain that increase will mean they rub on the wheelarch - rmember the outer edge of the wheelarch dips down closer to the wheel.
P_G
Re: RE: 275/35/19
Post by P_G » Mon Oct 27, 2008 2:26 pm
hussains wrote:I have had it changed to the 275/30/19.....I seem to be getting a light vibration at high speeds. Have had the balancing done twice. I am not sure if this is what is expected or the tyre company just cant get it right?
You are getting the vibration now you have the 275/30/19's? Have ran mine for 6k miles now and no problems, feel a little choppy when cold but all F1's have doen that on all the cars I have run in the winter, absolutely fine when up to temperature and loads more grip than the OEM Conti's they have replaced.
tartan_rob
Re: RE: 275/35/19
Post by tartan_rob » Mon Oct 27, 2008 3:26 pm
Agree totally.
2017 Kawasaki Z1000
2014 RS6
2014 S1
mac4RS
RE: Re: RE: 275/35/19
Post by mac4RS » Wed Oct 29, 2008 1:29 pm
I've driven @ BIG speeds (where you are allowed of course) with these tyres, and they are absolutely 'rock solid'...go to another tyre supplier & get them re-balanced again.
peterpan
Post by peterpan » Wed Oct 29, 2008 8:35 pm
PetrolDave thanx the info javascript:emoticon(':lol:') the others open here an other topic about their vibration that i do not interested in. javascript:emoticon(':evil:')
It seems i will remain at my oem size.
Peter
Users browsing this forum: Majestic-12 [Bot] and 190 guests
