Torque wrench for RS4
RE: Re: RE: Torque wrench for RS4
Got a track day coming up...will let you know how it goes. Street wise, they feel more grippy and quieter.
I still have problem with my shocks though, when both rear ones were replaced shortly after the both front replaced, I now get an annoying clanking noise over small bumps at low speed (sounds like a car jack not held down properly but as you know, there's no jack & I have even removed everything out of the rear compartment). The noise is much less if the car is loaded up with more people?##!#! They think it might have to be with the pressure charged a bit too high. I'm booked in to leave the car there with the master tech to try to sort it out. If anyone have any idea what's wrong with it, please feel free to let me know. Thanks.
2007 RS4 B7 - Phantom black saloon
Marcus-RS4
Sounds like a classic DRC symptom i.e. one/some of your shocks have failed... check for leaking?
Thanks Marcus for your input.
Can one or more of the 4 newly replaced shocks leak again that soon? I heard the clanking right on the day I picked up the day but I thought it might have been "new" shock and take some bedding in but unfortunately, it hasn't gone away after 5 weeks.
Marcus-RS4
Its the exact sound I heard when my shocks went, and I gave exactly the same analogy to what it sounded like...
I have heard of shocks failing soon after (weeks) install of the new ones, this is usually due to a poor installation and the pressures not being correct, the longer you leave it the worse it will get!
I just picked up the hydraulic jack this morning so will take the wheels off and take a good look at these shocks this weekend and will report back. As I said, the car is booked in for further diagnostics but I'll be very p*** if I find any leak with these new shocks!!!
i've had the same shock replaced 4 times in 3 months, so yes they can go so soon after replacement...
Re: RE: Re: RE: Torque wrench for RS4
Arrrggghhhhh....looks like it is happening to me too!dom888 wrote:i've had the same shock replaced 4 times in 3 months, so yes they can go so soon after replacement...
Good price for a decent torque wrench here http://direct.tesco.com/q/R.100-0381.aspx
Curiously, what is the difference between a 8E and 8D?Yep, 120Nm for the RS4 8E, and 140Nm for the RS4 8D. From the Audi Workshop manual.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
B5 (8D, 1994–2001)SR71 wrote:Curiously, what is the difference between a 8E and 8D?Yep, 120Nm for the RS4 8E, and 140Nm for the RS4 8D. From the Audi Workshop manual.
B6 (8E/8H, 2001–2005)
RE: Re: RE: Re: RE: Torque wrench for RS4
Thanks.
So what is the torque for the wheel nuts on the B7 then?
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
- PetrolDave
Re: RE: Re: RE: Re: RE: Torque wrench for RS4
B7 = 8ESR71 wrote:So what is the torque for the wheel nuts on the B7 then?
RE: Re: RE: Re: RE: Re: RE: Torque wrench for RS4
Ta.
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
In terms of "how quick can they leak" I'm sure I'll be bettered on this, but i have a front failed after 3 months and about 2000 miles.
rjkflyer wrote:Yep, 120Nm for the RS4 8E, and 140Nm for the RS4 8D. From the Audi Workshop manual.
what does 8E and 8D mean exactly ?????
Users browsing this forum: No registered users and 109 guests
