Anyone using ap22?
Re: Okey, now its official I have braindamage ; )
yeah im off to see an RS4 on friday - sold my S4 last week and im missing it already!
Ex '98 S4, Red, Bose
RS4 to be [img]images/graemlins/smile.gif[/img]
That's what I said above Rob (but a tad more accurate [img]images/graemlins/tongue.gif[/img]) - you bin on the Stella tonight? [img]images/graemlins/beerchug.gif[/img]
Well yes I have actually, but you said 6.9 not 0.69!
Oh and I'll be happy to do some road test figures in a fortnight or so [img]images/graemlins/laugh.gif[/img]
RobK
www.nogaro.org
www.nogaro.org
Good point, should be on Stella rather than Vladivar [img]images/graemlins/tongue.gif[/img] The decimal point can destroy the strongest man [img]images/graemlins/roflmao.gif[/img]
Rob, your help on this will be much appreciated [img]images/graemlins/thumbs.gif[/img]
Andiroo
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
new file 30-100mph 4 gear
So in my baby it took 10.75 seconds from 30mph to 100mph. the other runs I had to ease off because of traffic.
Re: new file 30-100mph 4 gear
Cool, I will post mine up later [img]images/graemlins/wink.gif[/img] So what does that 'Y' axis show? And please confirm all of your config so that we can show like for like [img]images/graemlins/thumbs.gif[/img]
Andiroo
Andiroo
edit: sample interval was 0.05 and the runs were accel. continious.
Y is g-smoothed. X mph
I found better busstop but now I cant see the comeing traffic so only 1/3 of the run are good. I'll try early sat. sun. mornings to get full 0-200kmph.
wether was good 7 C
other setup is:
mass 3701 lb MY 98 S4 sedan full run with full tank other two with nearly empty tank.
cda 0,69
roll res: 19 235/35 pirelli nero 0.015 estimate
tilt factor 0.010
roll factor 0,014
smoothing 0.004
top HP showed 303-307whp @ 91mph witch sounds alot for stg 2+.
wether was good 7 C
other setup is:
cda 0,69
tilt factor 0.010
roll factor 0,014
smoothing 0.004
with your tilt factor and roll factor, is your suspension standard? [img]images/graemlins/rocker.gif[/img]
Just done a few runs and this was the only one with no traffic.
4th gear only, 30mph=1600rpm in 4th with boost coming in at around 3200rpm.
Indicates 418hp peak at the wheels, which when adding a factor of 42% = 593bhp at the flywheel. Rolling road next week will confirm how accurate this is
, but doesn't seem too far off.
Andiroo
, but doesn't seem too far off.Andiroo
more details
I have KONI orange with some lowering. family car with hard winter conditions so not too low or hard.
I thing tilt does not affect these kind of easy starts unless you have crasy power and soft suspension.
I measured the runs with continious accel so I could do more accurate graph.
Just tried one run in 4th.
15.9s [img]images/graemlins/blush.gif[/img]
Standard S4
David
Standard S4
David
Indicates 418hp peak at the wheels, which when adding a factor of 42% = 593bhp at the flywheel. Rolling road next week will confirm how accurate this is [img]images/graemlins/wink.gif[/img], but doesn't seem too far off.
Andiroo
Where did you find out about the correction factor for ap22?
42% would give too much power in my case. IMO 433hp with k03 is not going to happen. normal dyno whp is something like 17-22 % correction and usually calculated as xwhp/0,78 if 22% loss used. that should give me 307/0,78 = 393 witch is too much too. 17% makes 370 witch I believe with 7 C is absolute max possible ever for k03's. then again these are not absolute numbers but useful when comparing different setups
The rule of thumb for flywheel bhp down to ATW Bhp is to take off 28% losses thru the quattro drivetrain. To convert "At the wheels" bhp back to flywheel bhp you therefore add 42%. Check out Bushy's ATW figure of 320bhp at G-Force Rolling Road and you'll see what I mean [img]images/graemlins/wink.gif[/img]
Andiroo
Andiroo
Does it matter that my 4th gear is different to yours? Also, are you setting off from a standstill and changing into 4th before 30? If so, what speed are you changing so the turbos have spooled up in time?
RobK
www.nogaro.org
www.nogaro.org
Hey mate [img]images/graemlins/wink.gif[/img] I basically bumbled along in 4th around 25mph then floored it waiting to reach my magic 3000rpm - so the turbos weren't spooled at all really. Just trying to get a good speed range in one gear so that we can compare, without adding unknowns like launches and changing gear. Do you think this is a good range/gear to use to compare say S3/S4/RS2/RS4?
Andiroo
Andiroo
Audi S3`s turbo kicks in at around 1000rpms quicker than yours [img]images/graemlins/tung2.gif[/img]
Riz [img]images/graemlins/s3addict.gif[/img]
I`m just a hardcore petrol head Who is online
Users browsing this forum: No registered users and 26 guests
