What are these ????
What are these ????
S4 avant nogaro blue '04' bog standard apart from LPG conversion & B7 milltek catback system (resonated)
Bluebrakes
RE: What are these ????
I am guessing they are for the FIS display system.
This will tell the dashboard what the radio is doing and display the track number/radio station.
One wire will be a pos + feed
One ground
One Data Line
One Clock Line
One ENA line
One TX line
One RX line
Because I'm working on a little project of my own to eventually display info on the dashboard regarding boost pressures, air intake and whatever my new radio will be playing.
One ground
One Data Line
One Clock Line
One ENA line
One TX line
One RX line
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
- PetrolDave
Re: RE: What are these ????
That's true on an early (analogue clock) B5 S4, but later (digital clock) B5 S4's and all B6 & B7 S4's use the CAN bus to carry this information to the FIS/DIS.Bluebrakes wrote:I am guessing they are for the FIS display system.
So if archboldm has a late B5 or a B6 or B7 there will be a different explanation.
Personally I never rely on colours as a guide of the function of wires in cars - they can (and do) change between model years.
RE: Re: RE: What are these ????
thanks for your input lads.My car is a "53"S4 avant.The ends are black if that helps,I took some photo,s of it,but I'm buggered if I can find out how to download them ??
regards Mac
regards Mac
- PetrolDave
Re: RE: Re: RE: What are these ????
So that's a B6 then? At least my May 2003 S4 Avant was a B6!archboldm wrote:My car is a 2003 S4 avant.
So they are not clock/data/enable DIS connectors, since the B6 uses the Infotainment CAN bus to carry that data.
RE: Re: RE: Re: RE: What are these ????
Yes Dave,it is indeed a B6, the DIS functions perfectly,so they're not for that,dont know if my car has a function that I dont know about,cos I only bought it recently !!
Mac
Mac
- PetrolDave
Bluebrakes
Users browsing this forum: Majestic-12 [Bot] and 64 guests
