What are these ????
archboldm
What are these ????
Post by archboldm » Wed Aug 27, 2008 2:24 pm
:? Having removed the symphony head unit to install RNS-E,I found 2 connectors,male & female that appear to connect to each other but were disconnected ! 2green,2 white,2 grey & 2 purple.Can anybody tell me what they are ??
S4 avant nogaro blue '04' bog standard apart from LPG conversion & B7 milltek catback system (resonated)
Bluebrakes
RE: What are these ????
Post by Bluebrakes » Thu Aug 28, 2008 1:52 pm
I am guessing they are for the FIS display system.
This will tell the dashboard what the radio is doing and display the track number/radio station.
One wire will be a pos + feed
One ground
One Data Line
One Clock Line
One ENA line
One TX line
One RX line
Because I'm working on a little project of my own to eventually display info on the dashboard regarding boost pressures, air intake and whatever my new radio will be playing.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
PetrolDave
Re: RE: What are these ????
Post by PetrolDave » Thu Aug 28, 2008 3:40 pm
Bluebrakes wrote:I am guessing they are for the FIS display system.
That's true on an early (analogue clock) B5 S4, but later (digital clock) B5 S4's and all B6 & B7 S4's use the CAN bus to carry this information to the FIS/DIS.
So if archboldm has a late B5 or a B6 or B7 there will be a different explanation.
Personally I never rely on colours as a guide of the function of wires in cars - they can (and do) change between model years.
archboldm
RE: Re: RE: What are these ????
Post by archboldm » Thu Aug 28, 2008 4:15 pm
thanks for your input lads.My car is a "53"S4 avant.The ends are black if that helps,I took some photo,s of it,but I'm buggered if I can find out how to download them ??
regards Mac
PetrolDave
Re: RE: Re: RE: What are these ????
Post by PetrolDave » Thu Aug 28, 2008 4:28 pm
archboldm wrote:My car is a 2003 S4 avant.
So that's a B6 then? At least my May 2003 S4 Avant was a B6!
So they are not clock/data/enable DIS connectors, since the B6 uses the Infotainment CAN bus to carry that data.
archboldm
RE: Re: RE: Re: RE: What are these ????
Post by archboldm » Thu Aug 28, 2008 5:24 pm
Yes Dave,it is indeed a B6, the DIS functions perfectly,so they're not for that,dont know if my car has a function that I dont know about,cos I only bought it recently !!
Mac
archboldm
Post by archboldm » Thu Sep 04, 2008 2:52 pm
FOUND OUT !!! extra connectors for my parrot.
PetrolDave
Post by PetrolDave » Thu Sep 04, 2008 3:25 pm
Ah! So they're not Audi wiring, that's why none of us knew what they were.
Bluebrakes
Post by Bluebrakes » Thu Sep 04, 2008 6:49 pm
doh.
very true. they do change colour occasionally. But as a rough guide the for the area it was. A good enough guess. ;-)
archboldm
Post by archboldm » Thu Sep 04, 2008 8:48 pm
thanks for your input anyway lads,it's appreciated !!
Return to “Electrical”
