Irratic Idle
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Blue_Thunder
Re: RE: Re: RE: Irratic Idle
Post by Blue_Thunder » Sun Aug 31, 2008 11:14 pm
Mentor wrote:Coolant temp sensor seems to be working fine. I had a faulty one before and the water temp gauge was all over the place, sometimes reading 90 then 60 then 0. I'd have to agree with you that the fueling does seem to be off, but because of what remains the mystery.
IIRC the cooant temp sensor sends seperate signals to the ECU and the gauge on the dash. When my coolant temp stopped working on the dash, the engine was still running fine. Checking on the Climate Control unit or Vagcom, you could see that it was correctly showing the coolant temp.
So in summary, don't believe what the gauge is telling you! It may be correctly registering 90 on the gauge, but sending different readings to the ECU.
Bluebrakes
Post by Bluebrakes » Sun Aug 31, 2008 11:28 pm
Air intake on intake just before throttle body which then splits through the boot to both sides of block.
MAF sensor after air box and just before silver y-pipe (on top of engine), which then goes down to turbos.
MAP? Really? You not thinking Charge pressure sensor? ;-)
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
dazzer
Post by dazzer » Mon Sep 01, 2008 12:47 pm
Bluebrakes wrote:Air intake on intake just before throttle body which then splits through the boot to both sides of block.
Semantics? It's a pressure sensor.
Thought the Air Intake temp sensor was after TBB. Got a pic of where it is?
Bluebrakes
Post by Bluebrakes » Mon Sep 01, 2008 9:32 pm
Probably the best i can do without taking a pic.
dazzer
Post by dazzer » Mon Sep 01, 2008 11:17 pm
Bluebrakes wrote:Image
Good pic. Looks like the AIT sensor is plumbed into the inlet manifold but sits below the plenum. Would that be fair to say?
Bluebrakes
Post by Bluebrakes » Tue Sep 02, 2008 6:06 pm
pretty much.
The diagram is actually a scan from audi's training manual on the 2.7l v6 engine. I have got a copy of the training manual, which is where i learnt some of my stuff. I prefer the practical learning ;-)
They use the same engine in the old A6, not as powerful, (230bhp i think) etc.
dazzer
Post by dazzer » Tue Sep 02, 2008 6:21 pm
Bluebrakes wrote:pretty much.
I have the same manual but must confess I haven't got round to reading it :notworthy:
