cam timing
cam timing
Can anyone clarify the cam chain setting process on a B5 S4? I have recently refitted my cams after changing the VVT gaskets & cam seals but have just read an article that says both banks are set up differently, not set up the same (16 links) as seen in ELSA.
I haven't started the car yet so it would be good to find this info sooner rather than later.
Cheers,
Mike
Cheers,
Mike
I DID turn the engine, but it was always the same.. 16 links on both heads.. At the beginning I had 16 links on both heads and the car was driving like S...
Then I put 15 links on the head where the cams marks didnt fit, and after that it was running like a dream... I know that ELSA said 16 links. Yesterday I had som RS4 heads, and there was also 16 and 15 links on the heads.. SO NO MATTER WHAT, THE CAM MARKS MUST FIT
the heads are the same they just face opposite directions,there should be 16 rollers between the marks on each cam,the mark on the exhaust cam(i think recalling from memory not elsa) is offset to the roller on the chain and is therfore difficult to read,hope this helps
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
the markings on the left hand bank are offset. the manuals do not show you how to time that bank properly. 16 rollers(mark to mark) but offsetted to the outside of hte heads.
http://www.MRCtuning.com
don't trust notches to pointers as that all depends on the tensioner position (fully up, down or in the middle)
So even if the motor is turned clockwise and brought up to TDC the notches still cannot be trusted?
I thought it was normal to have on tensioner up and one tensioner down during normal operation due to the tension sides of the chain being different, ie one is tensioned on the top and one is tensioned on the bottom?
I'm away so haven't finished the car yet, so it would be good to clear this up before I get home.
Cheers!
Cheers!
Users browsing this forum: Majestic-12 [Bot] and 39 guests
